KA won't start
Ok some backstory first:
I have an 89 s13 with a 97 KA in it. It was running fine up until last Friday when I was headed to work. It started up fine and I pulled away from my apartment no problems. About a mile from my apartment it bogged when I tried to give it gas and shut off a few seconds later. Now it won't start. The engine cranks, but won't start. I wasn't hearing the fuel pump prime so I replaced the pump, filter, and relay. Still cranks but won't start. I've searched but can't figure out what else it might be. Any suggestions? |
Checked spark from all the wires. I'm getting spark from those. Haven't pulled the spark plug itself out to check those yet. Would too low of fuel pressure cause it not to start?
Check your plugs for fuel. Had a 240 do something similar to this once, had an injector go wide open and start dumping fuel. replaced the injector and did it again. Ran the ground outside the harness(friends advice) and never had that problem again.
