![]() Join Date: Mar 2009
Super 80s Rustbucket 9000
So let me give you a little rundown of this fine piece of machinery. I purchased it about 2 years ago with some blown struts and I thought "easy fix" so I nabbed it for $1900 with 120k and thought I had a killer deal. So I limped it home in good ol' pothole ridden Rhode Island.
then...I tried to jack it off the ground and the rocker panel collapsed!! I look at the other side, same thing already happened over there...so I jack it up under the crossmember and it is now high enough to see this.....:insert dramatic reverb here: |
After I get the s13 all the way in the air I think "wait something doesn't look right...something is missing" then I realize there is no cat, the frame has about a golfball sized hole in the driver's frame rail and also the asshole that sold me this car has cut ALL the exhaust flanges and welded in some cheap galvanized steel piping all the way to the mufler!!! WTF!!! and I was wondering why it sounded like a raspy shit-rocket...
So mind you rust and shenanigans aside it doesn't appear that bad , so I decide to just ignore it for now until I do a motor swap or want to rebuild the KA that's in there now. So to freshen things up some I order the following things to freshen er' up a bit; -Catco cat -NGK iridium plugs -NGK wireset -ebay 4-2-1 header -Bosch 02 sensor -ebay catback -circuit sports exhaust hangers -tokico blue strut kit and got some strut mounts from a member here ![]() |
#3 | ||
AFC #1
![]() Join Date: Oct 2003
I assume this was an attempt at a build thread: Quote:
