Old 05-02-2008, 12:10 PM   #1
tylerdurdon
tylerdurdon is an unknown quantity at this point
engine bearing choices and preferences
So i am in the middle of a rebuilt on my sr20det and the last thing i have to get is the bearings and was wondering if anyone had any preferences on a certain brand, besides OEM, that they have used or seen good results with. the engine is getting a stock rebuild with some minor hardware upgrades and is not going to see any huge boost numbers. i appreciate any input anyone has.
tylerdurdon is offline   Reply With Quote
Old 05-02-2008, 01:17 PM   #2
Sileighty_85
Sileighty_85's Avatar
im running Nismo Main's with Tomei Micro Finished Con-Rod Bearing. No Problems I Love'em you can find them at www.RHDJapan.com
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-02-2008, 02:46 PM   #3
tylerdurdon
Thank you very much for the info and link. Those bearings look very well made but are a bit on the high end of what i would want to spend. they sell those by the half and per cylinder which would make it around 400 dollars or more for bearings. i also noticed that just like oem they have different sizez/colors and not just an all around standard size, would it be best to take a dial on each journal of the crank or is it ok to just go by the stamping on the block/crank? thanks again for any information.
Old 05-02-2008, 04:39 PM   #4
Sileighty_85
they should sell them as 1 cylinder each so you get two bearings for 1 set
後輪駆動車1番
1986 SR86 - 200ish
Old 05-02-2008, 05:48 PM   #5
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
clevite 77s for me
Seller feedback>>#/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 05-02-2008, 08:14 PM   #6
tylerdurdon
did you just plasti gauge the oil clearances? nissan was saying i needed to look at the stamps on the block and the crank to make sure i got the correct bearings but then people like beck arnley and clevite and acl for instance, your able to buy a complete pack of std size.
Old 05-02-2008, 10:32 PM   #7
Sileighty_85
When I was building my Block I only had my machine shop bore and hone the clyinders, and blance the crank.
They said my crank was perfect so they said I could use Standard bearings.
But when I was putting it together I still plasti gauged the bearing clearance and everything was gravy
後輪駆動車1番
1986 SR86 - 200ish
Old 05-02-2008, 10:33 PM   #8
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
i use oem
works greeeeaaaaaaaaaaaaaaaaaat
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
Old 05-03-2008, 10:34 AM   #9
tylerdurdon
awesome thanks for the info guys, seems like different people have gone different routes and ended about the same, as far as brand goes, i always plastigauge my oil clearances it just kinda through me off when the nissan dude started talking about different casting numbers and colors of rod bearings. i may call him back and talk to him some more to find out wtf he is talking about.
Old 05-03-2008, 10:51 AM   #10
Sileighty_85
if you look at the SR FSM it explains that whole process
後輪駆動車1番
1986 SR86 - 200ish
