#31 |
![]() Join Date: Feb 2017
You know when you go to the gas station and release pressure from the gas cap? Like the actual cap was defected from the back pressure some how.
#32 | |
![]() Join Date: Jul 2001
Err someone mentioned something about clogged fuel filter and excess pressure in the tank. I'm been running a z32 tt fuel filter for the longest time. Dunno if that makes a difference or not either. Maybe less prone to clogging vs oem 240sx-sized fuel filter. I dunno, just throwing some ideas out there. Last edited by MrMigs; 10-25-2018 at 11:55 PM.. Reason: about fuel filter |
#33 | |
![]() Join Date: Nov 2005
From what Ive gathered theres no real benefit from registering a classic car other than cheaper registration. It still needs to get smogged IIRC
#35 | |
![]() Join Date: Jul 2005
I've also seen a local fabricator make a pair of aluminum fuel tanks for a boat easily enough. If you have the tig, the tools, how hard can it be? I might even ask if I see him in the near future what he thinks. I just don't like to ask questions about making stuff that I don't intend to have made up asap, waste of time, but this isn't such a big deal IMO. |
#36 |
![]() Join Date: Jan 2010
here is what most impala tanks look like:
![]() Here is what a s14 tank looks like: you are comparing apples to oranges. the complex shape of the s14 gas tank cannot be simply replicated like a square impala tank can. don't you think if it were that easy someone would have already chimed in and made one? have you made one of these? if so, I would love to see pictures. |
#37 |
Kingtal0n this shit gets you nowhere bro trust me. Let them do/think what they want lol. Once all the tanks run out someone will do figure out a new method.
Dont be a pussy...Leave your name |
#38 |
I'm not trying to argue, just stating that having a fabricator build a few tanks with a shape like that is going to be $$$. its not an easy shape to replicate and would require a talented metal worker.
it would be cool if someone here has a contact/hookup to an injection molding company. do a group buy and hopefully if there is enough interest, do more, or keep a stock of some. https://www.plasticomnium.com/en/aut...l-systems.html |
#39 |
![]() Join Date: Mar 2008
Making a copy out of fiberglass could be viable solution. I just searched on it briefly and it looks like a specific type of resin and coating will have to be used it to make it resistant to gasoline and ethanol.
#40 |
![]() Join Date: Aug 2002
Maybe commission a shop to make a custom fuel tank that will pass evap?
Maybe these guys or something similar? http://www.boydwelding.com/ |
#41 | |
Yep... Fuel cell is probably the answer. Anybody here ever do the idea I have and rhino coat? My thought process would be if your tank is in perfect condition, the rhino coat will bind it and give it strength so something like a stress fracture hypothetically wouldn't occur.
I Love Drifting Thread > Drifting is Stupid thread |
#42 |
Sometimes having somebody telling you that something is impossible or difficult is just a motivational speech. Find it in your heart to thank those individuals for without them, who knows what wouldn't be invented.
In the above example I agree that the shape is complicated and agree that it could be very expensive and not to get our hopes up for a low cost solution anytime soon, but personally if I had access to the material and a tig I could create something that would fit. And I also believe that somebody will find a better/affordable solution when necessity breeds creation in a higher method that maybe easier than welding. Everybody is correct and its still fun to discuss and re-evaluate in idle time because this also may stew up new ideas. |
#43 |
It's just a slightly odd shape. Shit, you people are acting like it's something out of this world... For someone experienced with metal bending and welding, and with a chassis, or at least the rear half cut to be used as a model, it shouldn't be that hard. Obviously it will have square edges and might be a little larger or smaller, but as long as the mounting points, the pump base and breathers are the same, it should be all good. Shit, if I had to I probably would give it a try, except I would make it out of steel since Im not good with aluminum.
Check this one out ![]() for the f-body, a not so simple shape, and they sell for $600 here's a site with more pictures: https://www.behindbarsracecars.com/C.../bbrcc9802.htm No wonder people out there don't get shit done, they set themselves a lot of barriers...
Tuners are big bullies
#44 | |
As I said before, there was someone who I know is very knowledgeable regarding fabrication and cars, and this person on a now retired forum (or I would pull up their details and post here) explained that it really wasn't feasible. Doesn't at all mean it can't be done, just that it won't be an easy or cheap thing to do, and will likely cost more than the large majority of our niche community would be willing to spend. Even that F body tank you put up is much more simple than the s14 tank. It's definitely IMO the biggest s-chassis design flaw among all the chassis from 12-15. Nissan screwed up on the design and materials big time.
#45 |
I say fuck copying the original design, just make what fits. I would be ok with even sacrificing a few gallons of fuel capacity if I could have an aluminum tank that never leaked.
Sent from my SM-G935T using Tapatalk |
#46 |
![]() Join Date: Jun 2004
Trader Rating: (73)
I don't want to do another tank in the near future... the one I put in is good and holds a full tank of gas with no leaks... for now.
#47 | ||||||
![]() Join Date: Apr 2006
the only issue that is big here, is that the tank doesnt just hold fuel, it also holds the pressure unit needed for obd2 functionality. this is in the later tanks, its actually molded into the tank. as these cars get older, the only solution will be fuel cell... or convert your car to electric. ive already posted on this problem years ago, i was able to fix this issue by heating the tank (empty, of course) with a heat gun - and then basically melting nylon (from zip ties or somewhere else) and just plastic welding the two together. it works surprisingly well. however, my car is no longer compliant as i ditched the charcoal canister/evap system - the tank is no longer being pressurized as it originally was. i still have the flip valve, so it holds fumes... just not the same amount of pressure as originally designed. |
#48 |
Maybe S15 won't be 'thin'. I think that is the best way to handle this for those of us withing to keep 14s for long time as it eliminates probabilities for finding 'thin s14' versions. Even if it does cost 1k it becomes part of the cost of the car when you look to buy an S14 from now on, buyer wants $400 but its $1400 because everyone knows the fuel tank is bad. It suddenly becomes a car that only elitist can drive, everyone has a 240, few drive them, wham a new muscle car elite entry only is born
Until then however, I think i will find a leaking 14 tank. So I can practice fixing it and then have it on the side ready to go in case needed. Unless stumble on 15 I think this is the best 2 options for full capacity and best location (hidden well) for us now for a while. Otherwise throw a boat tank and go caution to the wind |
#49 | |
![]() You don't say. You know, I've never taken an s14 fuel tank down. And you know what, now that you say it, I have never even looked at a picture of one, I've heard it's IMPOSSIBLE to find one, so I don't even bother trying. I did however find a picture of this motorcycle gas tank with a super odd looking shape. But hey, it's got to be CGI, right? 'cause out of the picture ![]() ![]()
#50 | |
Trader Rating: (73)
#51 |
Hmm what doesn't make sense
Your options are: 1. used s14 tanks 2. used s15 tanks 3. fab a tank okay pick one. Whats that? used s14 tanks are going to all probably crack? Okay so fab one. What? It costs $1000 or some crazy fab work? Okay so then... what option is left over... did I miss a #4? sometimes I just wonder if you are a female, lack of logic power gives you away and its been consistently missing yet you never fail to point it out |
#52 | |
i know how to tig weld. i can tell you, the chances of fabbing up that tank out of metal are pretty much none. no one got time for that bullshit, especially broke ass 240 owners. cut the spare out of the trunk and install a fuel cell - done. but no, you're going to suggest we fab it up like that toy 2 gallon motorcycle tank. sure. |
#54 | |
#55 |
we never have this problem over in England with our 'euro-spec' s14's
the s15 tank is the same but the hose connections on the 'lid' are different on an s15 as the fuel hose are plastic so it has push on and click style connectors. also the fuel pump plug on the 'lid' is different to an s14 one.so your s14 loom wont plug directly into it. maybe see if cars that have lived in not so hot climates for longer periods of time suffer with bad tanks. it pretty much never gets over 30 degree Celsius over here. |
#56 | |
It could be other things, our cars probably stack mileage up faster in the states, but there are plenty of cooler climate regions in the US and people still have these problems. The tanks are no different from US -> JP -> EU as far as I know. FWIW, my s14 I am the second owner of and have owned for well over a decade and it hasn't been a problem even at 2xx,xxx miles. But I know that it is inevitable as, well, plastic sucks butt and will eventually rot. That is the nature of the beast. I started this thread due to I tend to forward plan things, and noticing the absolute scarcity of new tanks figured it was a discussion worth having now to help people circumvent the issue going forward. I do agree with ixfxi though, I think the only real legitimate option is fuel cell, it just isn't a perfect option unfortunately. I am very curious to see if I rhino coat mine will it have any real affect on the durability. I plan to replace my bushings soon in the subframe, so I think as I tear down the car, I may drop the tank and have it coated for science.
#57 |
Well... here’s a bump-
Pulled my s14 out of storage to bring home. Get off trailer, park it in the garage. Next day when I open the garage - gas smell is strong. No visual leak, but I have a feeling if I go to pull it that I will find one. So. Anybody else want to chime in? I suppose there really aren’t many new options. One thing is for sure, I really don’t like the idea of buying another friggin plastic tank. I don’t like the idea of cutting into my s14 - as it’s still rust free and pretty factory when it comes to the body, but I think a fuel cell is my likely answer.
#58 |
Have you confirmed a fuel tank leak? Does it leak only when full? Have you checked the fuel pump hanger/top hat. The Zenki s14 have terrible leaks there from around the actual electrical connections.
#59 |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
I sent an email via Nissan USA's website about this problem... who knows if it will go anywhere, but I mentioned this problem is occurring world wide.
#60 |
Not sure if anything will occur talking to Nissan USA and not Nissan Japan directly, but hopefully they hear the call and bring it back into production or do a small batch.
Nissan did bring back some r32 parts into production through the NISMO heritage program, but the r32 gtr is legendary. I would think the s14/s15 would hold some kind of meaning too. |
