When building a motor with a blown head gasket, what does Zilvia think about the necessity of replacing the rod bearings and main bearings as well as rings. I hear that that milk shake you get with a blown head gasket can cause your bearings to have premature failure after just replacing the HG and head bolts.
At this point I was planning to replace the following: Head Gasket (apexi) Head Bolts (ARP) Main & Rod bearings (Probably ACL) Rings And I was planning to deck the head. whats the likelihood of the block needing to be decked upon typical HG failure? |
![]() Join Date: Jul 2011
That deck has got to be clean. But it's not like everyone who replaces a HG gets the block resurfaced so it's posible. Just make sure it's super clean and take your time.
