Well my timing belt decided to shred and threw off the timing so I now have a very large paperweight. Basically everything besides the pistons and head are up for sale. I am located in St. Louis, MO and the best way to get ahold of me is PM me. All prices are OBO.
If there is something you want a picture of let me know and I'll gladly post one. RB20 Fidanza Flywheel (used less than 50 miles) $200 RB20 ACT 6-puck Clutch (used less than 50 miles) $200 RB20 Deatschwerks 650cc Injectors (used less than 50 miles) $350 RB20 Stock Injectors $100 ISIS FPR Bypass $10 RB20 5-speed Transmission with ISIS Short Shifter (modified of course) $300 Apexi S-AFC (with stand and extended harness) $SOLD RB20 Ignitor $60 RB20 CAS $SOLD RB20 Coilpacks (all of them work great) $40 each RB20 Alternator $75 RB20 P/S Pump $75 RB to S13 P/S Line (some wear, but doesn't leak) $30 Z32 N62 MAF w/ Pigtail $SOLD Altima N60 MAF w/o pigtail $30 HKS SSQV $SOLD RB20 ISIS Radiator Hoses $20 Mushimoto Radiator (RB or KA) with E-fans (wired with a relay) $SOLD Godspeed FMIC (Inlet/Outlet on same side) $100 HKS Turbo Timer with Nissan Harness $75 S13 Steering Column Gauge Pod $25 S13 Center Vent Gauge Pod $SOLD AEM Digital Voltage Gauge $75 RB20 Downpipe $SOLD S13 Megan Racing V2 Cat-back Exhaust (with test pipe) $200 McKinney RB20 Mounts (need new rubber mounts. I'm told McKinney sells just the rubber/poly pieces) Make an Offer Any sensors, or ANYTHING from an RB20 just send an offer. Last edited by Donut86; 06-12-2011 at 09:20 PM.. |
Is the air/fuel wideband?
I would be interested in the SAFC, Gauge pod for steering column, gauges in steering column.
S13 Digital Climate Conversion 1/3 BROWSE!! |
#17 |
Was up bro, hey dude im in the process of getting an s13 with an rb 20swap and in 1st and 2nd it sometime has like a stutter where it wants to turn off then i let of the throttle a bit and it goes back to normal, and also where r the spark plugs located,,,, I would appreciate the help thanks!!!
#18 | |
Under the coilpacks..Check the plug fluid first.
1992 240SX Coupe RB20 2003 350Z |
#24 | |
![]() Join Date: Apr 2010
.........Whipthis Drifting......... |
#26 |
Make sure to use 5w50 if the fluid is low........................
#28 |
460
2 bump limit. You can start new thread in 3 days.
| rb20, rb20det |
