Swapped KAs
I recently blew my old KA
![]() But thanks to a buddy of mine I was one for a decent price. Mind you me and some friends were drunk when we dropped it in But everything is plugged in and seems fine, now for the issue Car won't fire up nor idle. I'm getting fuel, I'm getting spar and I also timed the dizzy at TDC. I got it to spark and fire but only with the throttle at WOT. Any ideas? |
![]() Join Date: Sep 2008
Chassis and motor 13 or 14?
Was this a long block or complete motor? Did it run for your buddy, or did he just have it laying around? I'd start with MAF and TPS, just because that's where ive found gremlins in the past... |
s14 motor in a S14 chassis,
& it ran fine for my buddy. Even pulled on my old KA lol Idk it's weird. I'm getting spark....I'm getting fuel also. Seems like its out of timing even when I do time it :/ Ill be checking the tps & Maf today. Think it might be the iacv? |
![]() Join Date: Sep 2006
were all the grounds installed? (check them)
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
![]() Join Date: Jun 2007
^^Excellent idea!^^
If the grounds are good, have your friends come back over, get good & drunk and then take another look ![]() But seriously, verify your fuel lines aren't leaking, check all vacuum lines, connectors etc... Sounds to me like something simple but vital isn't connected if it ran fine in your drinking buddy's car. Word to the wise: Some things are better left unsaid lol
#11 | |
.#/f/engine-tech/3783...el-issues.html Read this, sounds similar to your issue... |
