S13 VLSD in S13 Open Pumpkin?
I know this may have been covered, but everything I read is on the J30/Z32 diff. Basically, this guy locally is trying to sell me the internals of a VLSD from an S13 without ABS, and it is in awesome shape with barely any miles. Will these fit in trouble free into my open diff pumpkin?
Thank you for clearing the confusion
WTB SR20 *Non-Rep* Bottom Mount Manifold WTB Bride Zieg II |
seriously need an answer! I don't need to know if a J30 pumpkin will fit into my S13. Everyone seems to think that is what I'm asking, and I'M NOT. I want to know if the inside of an R200 (not R200V) will fit right into my pumpkin and I will have a plug and play VLSD. Thank you.
#4 | |
![]() Join Date: May 2009
Search your answer is out there, in fact its pretty simple to find on google. I will not just give it to you because in the time since you posted you could have found it yourself.
![]() Join Date: Aug 2011
You DO realize that an S13 VLSD is a sealed unit and there is no way you can SEE if it has miles on it, do you ?
Also, do you honestly believe that a part coming from a car that has seen production halted 20 years ago could have "barely any miles" ? If so, i have tons of parts to sell to you. In case it was not self explanatory enough : ![]() |
