![]() Join Date: Jan 2008
TOMEI Turbo Kits on sale at ZEROLIFT - M7960 & M8270
![]() Zerolift is Proud to offer TOMEI products to Zilvia Members. The Latest sale is for the ARMS Turbo Kits for SR20det. The Tomei ARMS kits are the most complete bolt on upgrade we have used here at Zerolift. They include Turbo, Lines, Fittings, Flanges, Gaskets, Intake Adapter, Coupler ... literally everything.... Even 4 new Exhaust Studs for the Manifold. Both the M7960 and the M8270 Kits are on sale. Please contact us for Zilvia member pricing ! Please let me know the following when making an inquiry. - Which Kit you are interested in. - S13 or S14 Motor - and City, State, Zip Code Tomei Info : ■ M7960 TURBINE KIT This model is designed for low to mid range torque characteristics. The response is immediate with the light use of the throttle. Max boost is achieved by 4000 RPM. Best suited for street tuned cars and weekend track machines. Great for drifting, and grip race applications, with the best driving characteristics. PART NUMBER: 173019 $1,390.00 (USD) ■ M8270 TURBINE KIT This model is designed for high power at high RPM. With full boost on the bench test at 4,500 RPM and will maintain it all the way to high RPM without dropping. This will best suit the dedicated track cars that need best power at high RPM. PART NUMBER: 173020 $1,390.00 (USD) We have installed several of these on a stock engine platform. Most recently was a S13 SR20det with Head Gasket, Head Studs, 750cc Injectors, Z32 Maf Sensor, Tubular Manifold, 3" Exhaust, Front Mount, and ECU Tuned - The car made 318whp at 16PSI Please see the pictures below : Please let me know if I can help you with anything. Thanks, Mike
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift |
This is dyno sheet from most recent 8270 turbo vehicle. Built S13 SR20det, HKS 264 cams, valve train, greddy intake manifold 750cc injectors
![]() Join Date: Feb 2008
![]() Feedback Score: 29 reviews
Or if you're not-so stock...
S14 SR20det with built bottom end, Head Gasket, Head Studs, 740cc Injectors, lightweight fly, Z32 Maf Sensor, Tomei manifold/elbow, Front Mount, and Nistune- The car made 350HP/343TQ at 19.8PSI. Meia Dyno 7960 - YouTube (Green line is previous setup, stock fuel/tune, S14 Ported/polished/coated T28) Conservative tune, you know you want one of these! Absolutely!!! It's a rocket at 4k. |
![]() Join Date: Jan 2009
Trader Rating: (25)
I'm planning to go with a m7960 in the near future. How much power would I be looking at with a mostly stock S14 SR with cams and 660cc injectors at about 15psi?
Also, price for Milton, FL 32571 Thanks!
Thanks for the inquiry. We did a motor setup similar - with stock cams, head studs, and head gasket The car made 319whp at 15psi.
#9 | |
The turbos are not ball bearing. PM on the way ! Thank you
TOMEI ON SALE !!!!
Let us know what we can help with.
