![]() Join Date: Nov 2007
s13 left over parts
1 coil pack 15 bucks
1 stock sr turbo heat shield 15 1 sr redtop maf 40 1 sohc maf 50 1 maf adapter. not sure of the size 15 bucks 1 nissan sr oem oil filter 7 bucks 1 aftermarket oil filter . generic..same thing as above. 5 bucksgreddy profec b spec 2 boost controller with about 400 miles. 260 bucks apexi oil pressure gauge with sensor. new 180 apexi control unit 50 bucks apexi boost gauge 60mm 90 bucks We all know what these parts look like, pics aren't necessary but can be had. make offers!
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 Last edited by SoguRacing; 10-02-2009 at 06:56 PM.. |
yes it is. it's the one that covers the exhaust manifold. not sure if it will work with the gt2871. it seem like it would. the gt2871 actually sits a cm or 2 further away from the manifold i think.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
