![]() Join Date: Feb 2002
Enjuku Racing - ISR Performance Test Pipe - Nissan 240sx 89-98
ISR Performance Test Pipe - Nissan 240sx 89-98 ![]() This ISR test pipe is a high performance part that is intended for use in an 89-98 Nissan 240sx. The upgraded test pipe replaces the stock catalytic converter, increasing exhaust flow. Upgrading your catalytic converter to ISR’s test pipe is a great way to improve the performance of your engine. This is because catalytic converters are designed to regulate the harmful chemicals that are coming out of your car. Stock converters can certainly do the job, but usually at the expense of engine performance, as they constrict your exhaust flow. An upgraded test pipe will take care of the chemical reducing process that your catalytic converter handles, while allowing for a greater flow and overall better engine performance. This kit includes all of the gaskets and hardware required for a complete install and features extremely high quality, TIG welded, stainless steel. Updated flanges are water jet cut from thick-grade stainless steel plates. All ISR Performance flanges are strong and well suited for high temperatures. Order Today The ISR test pipe is a high caliber performance enhancement that you can get from Enjuku Racing at a low price. We strive to carry only top tier performance parts that are designed and built for power and longevity. If you have any questions about our inventory, specific parts, or your own configuration, don’t hesitate to give us a call. We strive to deliver orders as quickly as we can, as soon as their ordered. Shop our store and order your test pipe today! ** All ISR Performance Products are Designed for Off Road Use Only ** In Stock and Ready to Ship! $54.99
Hello Damian,
It's a straight pipe. It's not resonated in any manner. Just has a transition up and transition down. In terms of performance benefits it would be marginal at most but essentially it will be a 3 inch flow. Thank you! [email protected]
