![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 3 reviews
Power fc boost kit question???
i have a s13 sr with gt28rs turbo 550's, pfc d-jetro, and some other things, but i recently got it running pretty good and had to put a new wastegate on it because the old one was leaking, did that and all it wants to run is 10psi just off the wastegate no matter what setting in my commander i have it on just 10 psi, pretty sure its wired correctly into the ecu and i have the vac lines correct too. i have tried all kinds of boost settings but no change
any help greatly appreciated! |
With ignition on engine off, blow air in your apex map sensor (with your mouth not 100psi from air hose), solenoid should clicks loud.
if not, check the wire for power. It should have 12v to one and blinking ground on other with pressure in map sensor. |
![]() Join Date: Dec 2006
did you turn on the Boost controller using the commander?
ok so i blew air into my map with ignition on and engine off and nothing happened at all? does this mean we have a wired off the boost solenoid wrong?
any other suggestions? thanks guys |
So now, check for power and blinking ground.
It should have power with ignition on. And if you don't have power on this one, your O2 heater is not getting power also. It's common harness problem. someone didn't wire it right. |
