#61 |
We were actually planning on sending that to the US to back the S15 up in Formula D. Instead we decided to build a "twin" for the S15 but with 326 aero instead of Works9 so it's back up for sale.
#62 | |
Trust me, These guys know their stuff. We are happy to be working with DrivingSports-Na.
#63 |
Thank you for this....I just found it which i was going to post up but you beat me to it..haha
#64 | |
#65 |
#67 |
![]() Join Date: Apr 2006
and yeah, cause ANYONE on zilvia, other than the handful, will spend more than that on coilovers lol
those ryo coils look pretty solid though, when my CSTs blow from the airbags, i might go get a set
2015 Subaru Outback Overlander - Wagonofdoom |
#68 | |
![]() Join Date: Oct 2004
I'll try to look for some, but I sold it when I put FN's on it back in the day when SPL came out with them. I will try to find some.
Drift Indy |
#70 | |
But they look pretty similar to everything else from Asia in terms of damping trends. Linear compression so there is either not enough compression damping in the low speed or too much in the high speed causing a rough ride. It looks like a lot of rebound, maybe around where it should be, maybe too much, but not very well balanced with compression. Since they're there, the GP Sports dampers don't look much better. More rebound which is probably not needed. And on the right plot it looks like the damper is seeing some cavitation probably a result of not balancing the adjusters with the bleed ports on the piston or not enough gas pressure. But that's all I can really say without more data. Tim |
#72 |
![]() Join Date: May 2002
thanks tim!! thats awesome
i dont get those charts at all. wish i knew more to buy quality coilovres but u cant get dynos fro anything it seems 1/2 the time that mag also did tein and some other stuff cst mostly jdm stuff |
#73 | |
Spot on with what i was going to say Tim.=)
www.nissanroadracing.com |
#74 | |
right.
#75 |
Well Brian, no. But that doesn't mean people won't buy them and claim that they're better than all the other entry level stuff. They're probably just another pick your favorite color setup.
Tim |
#76 |
Bh.... king of sarcasm
#79 |
More information
Here are the specs for the the RII Hi-Max Dampers. I've also included a list of drivers currently running them. Specs - Inverted Monotube Design - Oversized and Reinforced Piston - High-Grade Damper Seals - Application Specific Neo Synthetic Oil by Advantage - Chemically Treated and Coated Damper Casing - High-Strength Pillow Ball Upper Mounts - Forged Aluminum and Anodized Adjustable Camber Plates with Degree Markings - 15 Way Damper Adjustment (1 step is equal to an increase/decrease of 4kg/mm in spring rate) - Reinforced Adjustment Dials - Forged Aluminum Lower Brackets - Cold Wound Spring (2100n/m) Design - 8kg/mm (f) 6kg/mm (r) Standard Spring Rates (4.0kg/mm - 22.00kg/mm available) - 200mm (f) 240mm (r) Spring Height - Forged Aluminum Spring Seats and Lock Rings - Full Tap Design (height and rebound can be adjusted without effecting spring preload) - MADE IN JAPAN Driver List Takeshi - Crazy Night / V-Factory Jikuya - Crazy Night / V-Factory Namba Osamu - Skid Line Tihiro Sato - Skid Line Hiroshi Takashi - Junk Stock Takeshi Shinkawa - 326Power Yuusuke Tanaka - 326Power Tatsuki Takashi - Bross Running Crazy's / DrooP Kitashiba - Crazy Night / H.D.O. (D1SL West Title Sponsor) Hideo Itakura - H.D.O. (D1SL West Title Sponsor) Hidehiko Sugita - Shake of Worker Masahiro Yakushiji - 89Racing / NK Company Kazuya Mitinobu - 89Racing Yoshihiro Sato - 89Racing Kazuya Koyama - Ultra Groover Akihiro Tsuruoka - Ultra Groover Taro Makoto - Ultra Groover Takashi Itoo - Be Noisy Hiroshi Yasushi - Jets / DRIDE Atsuya Itagaki - Jets / DRIDE Akira Kajihara - Okayama Union Kiyoshi Kawabata - Crazy Night Fukuda - Crazy Night Fujio - Crazy Night Yoshinaga Ryo - Crazy Night / RYO (of course) Makoto Takashi - M-Bros Makoto Kudo - Garage Kudo Iku Saitou - West Auto Susumu Kushida - West Auto Takahiro Araki - Progress Humi Yoshi - Progress Shiyunsuke Sakamoto - Over Quality Kenzi Hanaoka - Club Man S Itirou Makoto - Seek Speed Hiroshi Matsuo - Seek Speed Satoshi Yamamoto - DAR Makoto Oti - Pleasure All of the drivers above are either running in D1GP, D1SL, MSC or a combination of the series and have seen the podium.
#81 |
![]() Join Date: Feb 2008
man it gonna be in the 1,000-2,000 or 3 if they want to cause jdm pro's uses it and they gonna be like yea man these coilovers is jdm tyte yo
