![]() Join Date: Apr 2007
Trader Rating: (50)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 50 reviews
95 5Speed SE S14 Part-Out!! SO-Cal! Everything Must GO!
1995 5 Speed S14 SE Partout
NO Engine NO 5 lug Prices Dropped! Complete 5 Speed Swap Transmission 150K Clutch/Flywheel Shifter and Lower Trim Brake/Clutch Pedals All Bolts (flywheel, clutch, transmission) Clutch Master/Slave Hard/Soft line Trans. Cross member Driveshaft ECU and Lower Harness SOLD GONE!!!! Interior: Clean S14 Dash (if not sold in 1 week Im keeping) _____________ $350 firm Front And rear complete seats (clean)_______________________ $350 $300 Door Panels____________________________________________ _ $100 pair $80 Rear lower Panels________________________________________ $40 pair $30 Rear upper B pillar Panels__________________________________ $30 pair $20 Center Console w/ Shifter trim______________________________SOLD SOLD Door Sills_____________________________________________ __ $20 pair $15 Pass and Driv. Fuse kick panels_____________________________ $20 pair $10 A/C Bezel w/ buttons_____________________________________ $50____ $40 Front seat belts_________________________________________ $SOLD Rear seat belts__________________________________________ $SOLD Headliner_________________________________________ ______ $40 ____$30 Front A Pillars For tweeters ________________________________$40 pair_$SOLD Body: Rear bumper____________________________________________ $30_____$20 Rear trunk with Se wing (pearl white clean)__________________ $100____$80 Tail lights____________________________________________ __ $80_____$60 Door Shells____________________________________________ _ $50 each $40 Window glass___________________________________________ $40 each_$30 Window rail _____________________________________ $50 each $Sold Complete Lock set (Doors, Trunk, Ignition) Will only sell outside CA $200 $150 Suspension: -S14 Tokiko Blue Shocks, (Clean) Eibach Pro kit lowering springs SPC Camber plates _______________$450 -S14 SPC Adjustable Camber and Traction Arms $250 I will update This thread with more pictures as items get removed!! For things Not Listed Ask In this thread Please inquire in this thread Only Don’t Bombard me With PM’s Thanks Most Pars For Pick up Only Shipping Available for small Parts!! Located In LAX Airport area In Los Angeles CA Sold: Visors se lip hardware Rear speaker cover rear caliper hood latch cable climate control Center console w/ shifter trim! 5 speed swap driver side view mirror Front and Rear Seatbelts Driver window rail and motor Passenger window rail and motor Wiper motor and amp Front and rear sway bars brake booster and master all brake hardlines gas pedal and cable axles and diff front brakes Last edited by essforteen; 09-08-2010 at 12:27 PM.. |
my first reaction: *gasp* he's parting out his car?! lol. does it have a full exhaust? also need drivers side window motor =] k thanks
1995 s14 Zenki - R.I.P 1992 s13 Zenki Coupe - KA-T
![]() Join Date: Sep 2009
![]() Feedback Score: 15 reviews
do u have a/c resistor?
its under the passenger side dash. if u can crawl up under the passenger side dash, and it's held in by two screws.... get those out, slide the unit out, bout the size of a credit card. pm me. we met before lol. went with my friend to buy exhuast.
straights are for fast cars, corners are for fast drivers. Last edited by sickstatus; 07-21-2010 at 05:06 AM.. |
#17 | ||||
Trader Rating: (50)
$50 pm sent Quote:
but buy the whole thing for $120 picked up Sorry its gone! |
#21 | ||
Trader Rating: (50)
Got it Quote:
Are you talking about the switch panels for the windows driver side doesn't work so well (switch is sensitive) and passenger side has a small crack |
#28 | ||
Trader Rating: (50)
a complete set, if one piece is damaged ill part it! Quote:
I really dont want to! All prices have been dropped i noticed they were kinda high so i dropped them! Don't be afraid to give me reasonable offers No LOWballs!! |
