![]() Join Date: May 2009
Where do S14 Engine and 5 spd tranny harness plugs go? Need help asap.
I have 8 plugs I cannot figure out where they go... Maybe you guys can help me out. I took pics of them all and I'll try to explain them as best as possible. I have the rest hooked up but I still gotta get these 8 ironed out. I think all the EGR shit is removed. All the little tubes are there but the unit is gone.
Now for the pics First up we have this one, found at the back of the tranny. Not sure where it goes. Then the next few are various tranny and engine plugs. The first is a green plug that is next to the injector plugs. same type of plug as the injector plugs. This one is near the plugs for the TPS This one is from the tranny/lower engine harness And the rest are either on the split off the engine harness (right after it comes out of the firewall) or from the lower engine harness. And this last one here is the same type of plug as the green one but it is brown and comes off the lower engine/tranny harness God I hope someone can help. Like I said I believe all the EGR shit is removed. All the hoses are plugged. |
![]() Join Date: Dec 2002
Picture 1 - Rear O2 sensor.
Picture 2 - EVAP purge solenoid. Picture 3 - EVAP purge volume control valve. Picture 4 - Oil pressure switch. Picture 5 - Not sure. Picture 6 - Wiper amplifier. Picture 7 - MAP-BARO sensor. There's an FSM for a reason. You should learn to use it.
![]() Join Date: Sep 2004
http://i368.photobucket.com/albums/o...727092238a.jpg that is the lower sensor harness plug for the transmission the wiper amp plug looks exactly the same. And are a severe bitch to de-pin their female counter parts. Simone : My 1996 240sx: Lower Harness is done dilli-yo! in the diagram above the fsm counter parts are listed next to the number.
Wayne |
Ok don't need the evap shit it is removed. Only two i have to figure out are the last picture, it comes off the engine harness over near where the wiper controller shit is. And the map baro sensor. I can't figure out where to plug it in at. Thanks. The rest are either unused or plugged in now.
The MAP-BARO is EVAP also.
#12 | |
Well thanks guys all but one is hooked up now. this is the last one
I don't know where it goes. It's on the passenger side it comes off the engine harness I believe. |
Some of them, yes. The EVAP stuff is all part of the engine harness.
#16 | |
You can also look up said wire colors in the aforementioned FSM, eliminating the need to even ask.
