![]() Join Date: Dec 2008
![]() Feedback Score: 20 reviews
Hello fellow Techs,
I just installed S14 Front Spindles and they're not sitting in the A Arm ball joint very well. It seems that the ball joint on a S13 is bigger than the S14 ball joint hole. It isn't sitting very flush with the bottom of the A arm or even near it. Also the nut on the top of the ball joint thread doesn't clear the cotter pin hole. It's hard to get a angle to push the spindle down far enough, I just got a ball joint puller today i could use it to also press the spindle further down the ball joint. Any ideas?? LMK. Thanks! |
S13 and S14 front ball joints are DIFFERENT. Do NOT try using this combo. You will most likely break something which would be bad news if you are cruising.
S13 = S13 S14 = S14 Do not try mixing them |
since S14 LCA's are harder to find, here's easier solution.
buy new ball joints for S14, Moog part number K9820 find a J30 Front LCA. problem solved.
S13 Front
Taper low diameter 15.8mm Taper High diameter 18mm Taper length 19.5mm Diameter where it presses in 41mm S13 Rear, R32 Rear Taper low diameter 15mm Taper High diameter 18.6mm Taper length 23mm Diameter where it presses in 38mm R32 Front. S14 F&R , S15 F&R Taper low diameter 15mm Taper High diameter 18.6mm Taper length 23mm Diameter where it presses in 41mm ^Here is the info you need. |
![]() Join Date: Dec 2006
