| Europe A place for our cousins from across the pond |
Z power from Portugal
This is my 300ZX project
1992 euro spec Z32 TT 2+2 LHD wiseco custom made piston eagle rods JWT mild cams JWT HD valve springs Stage 2 Ported heads and chambers and manifolds clevite77 bearings NA piston oil jets OEM oil pump Cometic HG ARP head and mains OEM gasket kit 300degree fuel rails nismo 740cc injectors nismo termostat 3" down pipes 3" to 2.5" test pipes 2.5" cat backs and 4.5” tips Nistune dual intake AEM wideband AEM water/meth Unorthodox racing pulley BilZki overdrive water pulley Z1 GT675 turbo kit Manifolds upgrade blitz SBC i-d III spec R blitz R VIT crome aluminiun hard pipes slicone hoses nismo radiator cap 1.3 bar NGK iridium IX ´8´ heat range ebay short shift Z1 motorsport dump valves magnetic engine oil drain plug goodspeed SMIC´s CZP EGR off kit Bosch o2 sensors XTD 6 puck clutch XTD flywheel SS clutch line CZP upgraded clutch fork and pivot ball CZP silicone brake booster to check valve CZP silicone brake booster check valve to plenum CZP silicone clutch booster check valve to plenum 1pc AMZ drive shaft 4 new slotted rotors and EBC red stuff pads SS goodridge brake lines Fuchs titan pro S 10w50 engine oil Rota grid drift 18" 8.5" front and 9.5" rears whit toyo´s R888 Megan racing EZ street coilovers and a lot more! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() Join Date: Sep 2006
daaamn. nice.
my thoughts: how expensive is it to ship all those US parts to Portugal? damn, ive never seen the VG's bores, theyre so big! have you considered getting rid of the stock, carpet like interior?
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
#3 | |
The costums is PITA , all imported parts most pay +23% tax... Yes i considered put the interior in black leather ![]() |
tks!
Im working now in BBK for it using the Evo brembos calipers! I already have the Brembos that i paint just like my stock ones to give that OEM look ![]() ![]() ![]() Only need the adapters and Rotors, im planing going to the EVO X rotors that is 350X32MM ![]() |
