Old 03-07-2009, 10:52 AM   #1
s13momentum
s13momentum is an unknown quantity at this point
Send a message via AIM to s13momentum
Fuel Guage not working HELP
i recently bought an s13 but the only bad thing was the fuel guage wasnt working. so i replaced the dash with my HUD(which was working on my other s13) and still it gave me the same results
I recently filled my tank and all it went to was a tad bit before half a tank and it always does this
does anyone kno what can be the cause of this??????
i dont want to go on my own and ruin something
s13momentum is offline   Reply With Quote
Old 03-08-2009, 07:34 PM   #2
rex2sx
rex2sx's Avatar
rex2sx is an unknown quantity at this point
It could be ab electrical problem. Yu check your wiring? Make sure you got voltage?
rex2sx is offline   Reply With Quote
Old 03-08-2009, 07:56 PM   #3
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
Its more than likely the float. remove the pump assembly and make sure its not broke or off.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 03-08-2009, 11:52 PM   #4
s13momentum
yea me and my friend used a DMM to it and it showed voltage and i took the whole pump assembly out and i found that everythings intact on the fuel pump
the only thing is that there was a metal baffle thing in the tank that moved around and was restricting the floater so i moved it out of the way(it was held on to a a wire thing in which was the tube to where gas enters the tank)and i moved it out of the way completly and now the guage works fine
should i remove that metal baffle in there cause when i looked at it it looked pretty damaged to me
