#31 | |
S12 || KN13 || S13 || B16 |
#32 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Whoops, sorry. I read somewhere they were different (or misinterpreted what I was reading) : #/f/s-chassis/243438...ml#post2727044
If you're going to all that trouble you should be swapping in z32 uprights anyway. |
#33 | |
![]() Join Date: Aug 2011
#34 |
i Google it , weight difference , so whats needed to do the swap on that with s14 subframe on s13, all the above aka s14 arms ruca rlca toe and s13 strut or coils with z32 mounts
#36 | ||
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I plan to RACE my car... not hardpark the shit out of it and say "yeah I have an S13 with all S14 suspension because I'm MadJDMTyte yo!" I have a set of rules to comply with and this mod has been done by more than a few other SM classed 240sx's and run for quite some time successfully WITHOUT offset bushings. Proof that this mod can indeed be safely completed WITHOUT the offset bushings. Thanks for the sweet words though. I almost blushed.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA |
#37 |
why isn't stretching the stock bushings considered offset bushings also? its offset from the original location just as much as the spl bushings are.
* S14SR22 * 9.0 c/r * GT3071R * |
#38 |
Since I am very interested in hearing about how to improve grip, this apparently must be added to my Excel spreadsheet of modifications planned
![]() e1_greigo, I may call/PM about this to make sure that I go about it right when the time comes. |
#39 | |
Trader Rating: (24)
Fair enough, it's all covered on NRR. This should come after you get rid of your tanabes. |
#40 |
I just found the NRR thread that is tens of pages on the subject so I will read it. I will probably try to redo my rear suspension all at once, with new springs, S14 sub frame, SPL bushings and SPL diff bushings, but I have to get the FI/ECU sorted first.
#41 | |||
![]() Join Date: Apr 2006
its all good though, because i plan to ditch CHP and gangsters rollin down the 710 freeway through the thuggiest of thug nasty parts of LA.. so your subframe is as good as mine. the best, more accurate description i can give you is.... why dont people walk around with a speculums up their crevices. if you're going to stretch something, i can understand doing that for a brief minute. when you stretch the fuck out of a bushing and are forced to mash it onto the body, thats ghetto. but for some reason folks from the land of no toothpaste and soap, think they know better. what do i know, i'm from LA. |
#42 |
I want to clarify in this thread, if you have an stock s13 and want to put a s14 subframe you will need...
1. s14 subframe. 2. s13>s14 conversion bushings. 3. s14 rear lower control arms? 4. s14 knuckles/spindle? 5. s14 toe links? It would be appreciated if someone could clarify that this list is accurate.
#43 |
And, I would love to hear someone's impression of driving their car after doing the swap: Can you actually feel a difference? Will the change help the most with straight line acceleration, or acceleration out of corners or ?
#44 |
![]() Join Date: Mar 2007
Trader Rating: (31)
Ok. I'm in
ixfxi & I have spoken on The conversion previously that I'm doing which is an Entire S15 rear end,suspension,Diff etc etc in mY S14. does the Driveshaft not have any implications on this Conversion?? I'm hoping my ABS S14 d/s works with my New S15 rear Subframe and everything. I'm almost ready to Install it w/in a few weeks. I would almost think about using the S14 Frame I'm going to remove and putting it in my S13 but its a Rusted Turd (whole reason for the entire Rear S15 under Clip I'm using) and would take more time in cleaning everything to me than Its worth.
z-tERty-2 |
#46 | |
read my sig.
#47 | |
All other things aside, the swap is a cake walk either way you do it. No rule set to follow, buy the bushings. Rule set to follow, join the large club of guys that have done it the OTHER way.
#49 |
#50 |
Man w/ CTSV & a Car Seat
I know first hand that I've felt the difference while drifting. S13 feels twitchy while going sideways, upgraded to an S14 subframe and the car felt alot smoother where you dont have to contstantly fight the car.
#51 | ||
I believe s15 puts the speed sensor in the s14 abs sensor location then adds a sensor on each diff output shaft. Stance's are cheaper if you don't want/need all the adjustment shims. That seems a little excessive, no need to change subframes just to swap diffs.
#52 | |
the s15 diff has the speed sensor in it. if you want to have a speedo still you would have to have the diff. BUT i dont know if the diffs are close to the same when it comes to where they bolt up, which is why i would assume someone would need the s15 subframe to run the s15 diff and im pretty sure with an s15 sr, wanting to run an s15 diff, you need the s15 ds as well...any other diff you can use the stock drifeshaft. |
#53 | |
the previous poster pointed out that the differential COVER is the only item that needs to be swapped, if you want to be cheap about it and not install a newer subframe. |
#54 |
@ixfxi
i see this. but im saying isnt the speed sensor in the differential? if you use the 6 speed tranny the speed sensor isnt there. what im saying is that if you want a 6 speed tranny as well as a speed sensor you would need the s15 diff.. unless the speed sensor is in the diff cover of the s15 then nvm everything im saying. lolz but if you had to swap full diffs i would assume having to change the subframe and DS. are you saying the speed sensor is in the diff cover ixfxi? |
#55 |
You are correct in needing the s15 diff with the speed sensor ,which is in the snout of the housing, but has nothing to do with the subframe. Any s-chassis diff will bolt into any s-chassis subframe as long as you have the proper rear cover that matches the subframe, s13 being 4 bolt and s14/15 being 2 bolt.
#56 |
i think its a no-brainer now in 2012, that if you want to run an s15 motor/trans/driveshaft/diff that you need the entire setup.. the speed sensor mounts on the ears of the diff cover, from what i remember.
#57 |
Is this also applicable for the front subframe? I'm asking cause they looked the same to me last time i saw an s14 subframe. I'm planning powered by max suspension all around and I wanna know if i should convert my front sub to an s14 one too and run s14 arms, tie rods, tensions, lca, etc. up there or not.
#60 |
![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Don't forget, this can get expensive if you don't have a press. the bushings themselves aren't that bad but if you get a shop to install them its like $500 labor
