![]() Join Date: Dec 2008
top mount clearance/heat issue
so as i put my car back together i notice that my turbo is damn near touching my brake booster. i was going to wrap the header and turbo and heat sheild the booster but its seriously TOUCHING the booster so a shield wont fit nor will a turbo wrap.
here are my options 1 the most obvious buy a better engineered top mount. but i cant afford one at the moment 2 modify my current top mount (cut off flange, grind and re-weld) (im leaning towards this one.) 3 find a smaller brake booster, and wrap/ shield like i would have originally. and here is a pic. i could really use some input and advice from others who have had this problem. Last edited by mattro; 08-30-2009 at 06:16 PM.. Reason: uploaded wrong pic |
I had this problem also, i took a couple washers and put them on the passanger side of the brake booster to get it away from the turbo a little bit. then i invested in a turbo blanket. i have not had a problem since.
#3 | |
WOW that is perfect. thanks a bunch that was some good info. ![]() what do you recommend a fiber glass once that fits snug or a metal once that goes around it? |
![]() Join Date: Oct 2006
that manifold is shit! For all the time and work you are going to put into making that work you mind aswell just buy a better one. Ichiba makes a decent t3 topmount for alittle more than that ebay junk. It looks/fits/works alot nicer. I ran my gt30r on it at a bunch of track events with no problems
thanks im looking into that now but for the moment i need to get this thing running. if i had the money i would but im kinda sort on cash iat the moment. having just bought a winter beater than needs some work |
#6 | |
i fully de-volved
will look into that, ive actually put some washers behind it and that did the trick for now.
grip like roots, float like leaves. wtb s13 sus. |
![]() Join Date: Dec 2003
You've got another problem too. That shitty collector gasket you got with your manifold is going to blow soon after running it.
just a fact for ya... I would definitely get a heat blanket and look into getting the compressor housing Ceramic coated
I have the same problem with a peakboost manifold, with the little space I have I think a turbo blanket may end up touching the BMC, would ceramic coating help enough to be a sole solution ?
#11 | |
and the gasket is w.e we have a local speed shop that stocks things like that
