#31 |
Man w/ CTSV & a Car Seat
1. S13/S14/S15 = s14
2. Suspension Setup = CRAP: Eibach sportlines/tokicos 3. Wheel/Rim Size front & back = 17x10 all around 4. Brand of Wheel/Rim = 5-zigen FN01R 5. Offset front & back = +12 all around 6. Spacer Size = None 7. Tire Size front & back = 245/40 front 255/40 rear 8. Alignment Specs = -.9 fronts -1.5 rear 9. Clear Zbrakes & what size brakes = clears 30mm Z brakes 10. Fender Modifications: rolled/pulled = ghetto pulled fenders all around |
#32 |
![]() Join Date: Jan 2005
1. S13
2. Stock dampers and TEIN S Tech springs 3. 18x8 all around 4. Infiniti/Nissan G35c OEM Wheels 5. +30 all around 6. No Spacers 7. 225/40/18 front 225/45/18 rear 8. Alignment Specs = Not sure probaly 1.5 degree front and 2.0 rear 9. Clears Q45 Brakes 26mm has lots of room 10. No Fender Modifications
#33 |
WOW addicted
![]() Join Date: Dec 2001
1. S13
2. Suspension Setup = JIC FLT-A2 3. Wheel/Rim Size front & back = 17x8 F 17x9 R 4. Brand of Wheel/Rim = Nismo LM-GT2 5. Offset front & back = +35 front +38 Rear 6. Spacer Size = none 7. Tire Size front & back = 215/45 front and rear 8. Alignment Specs = camber: -2.5F -1.7R toe: 0 all round 9. Clear Zbrakes & what size brakes = yes clear Z-brakes 10. Fender Modifications: rolled/pulled = none 11. Picture.. from the side & down the side = ![]() ![]() ![]() ![]()
#34 |
![]() Join Date: Apr 2003
1. 1993 s13 coupe
2. KYB AGX shocks / Espelir Active Super Down Springs 3. 15x7 front and back 4. Konig Rewind 5. +0 offset front and back 6. No spacer 7. Falken Zieks ze-512 195/60/15 8. No deliberate alignment, whatever camber the drop gave me *needs alignment bad though* 9. Unsure about Z-Brake clearance, stock s13 brakes 10. No fender mods *rear could be pulled a wee bit*
#35 |
![]() Join Date: Mar 2004
2. Suspension Setup = tein soft techs & agxs 3. Wheel/Rim Size front & back = 17x8 4. Brand of Wheel/Rim = Mille miglia ht3 5. Offset front & back = a very conservative +35 6. Spacer Size = 0 7. Tire Size front & back = 215/45/17 front, 225/45/17 rear 8. Alignment Specs =just under 2 degrees front camber and 2.5 rear 9. Clear Zbrakes & what size brakes = yes 10. Fender Modifications: rolled/pulled = nope 11. Picture.. from the side & down the side = Looking to upgrade more than a few things but hey they were cheap, at least i know they're weaksauce.
ROUND 2 |
#36 |
![]() Join Date: Feb 2003
1. S14
2. KTS coilovers 3. 17x9 4. Impul R5 5. +20 f/r 6. no spacers 7. 235-40-17 r-s2 f/r 8. Alignment= nightmare. To be taken care of this weekend 9. believe so 10. no fender mods, maybe roll slightly once alignment is corrected... 11....
My car has been sold Last edited by KOUKI KA-T; 01-14-2006 at 06:10 AM.. |
#37 |
![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
1. S13
2. Megan coilovers 3. 18x8.5 & 18x9.5 4. Sportmax Racing 962 5. +35 F/R 6. 10mm spacer all around (+25 effective all around) 7. 225/40 F 245/40 R Falken ST-115 8. Alignment= nightmare. To be taken care of. Decent camber in the rear (at least -2.5-3) Fronts still need more spacer and more camber. 9. 30mm Z brakes/coilovers 10. Fenders rolled all around Bryan
#38 |
![]() Join Date: Feb 2005
Updated Finally!!
1. S13/S14/S15 = S14 2. Suspension Setup = AGX with Tanabe DF210 springs- Powered by Max Ruca's & Toe Rods. Wicked Tunning's Tension & Tie Rods. 3. Wheel/Rim Size front & back = 18x9 front 18x10 rear Motegi Togue Wheels 5. Offset front & back = +12 front +30 rear 6. Spacer Size = None 7. Tire Size front & back = 235/40/18 front 265/35/18 rear 8. Alignment Specs = Done at Trueline El Cajon, CA 9. Clear Zbrakes & what size brakes = Front 30mm Z Brakes with 350z track rotors (not shown in picture) Rear stock brakes w Brembo Blanks & Metal Master Pads 10. Fender Modifications: rolled/pulled = Rolled Rears only 11. Picture.. from the side & down the side = See below
Last edited by samms95s14se; 12-18-2007 at 02:12 AM.. Reason: Information Update |
#39 |
2. Suspension Setup = Megan Racing Coilovers (Street) 3. Wheel/Rim Size front & back = 17x9 F/R 4. Brand of Wheel/Rim = Motegi Racing Touge - Yeah, they're crap but they work 5. Offset front & back = +24 F/R 6. Spacer Size = None 7. Tire Size front & back = 235/45 F/R 8. Alignment Specs = Horrible. Whatever I get with stock suspension arms and drop. 9. Clear Zbrakes & what size brakes = clears 26mm z32 brakes...not 30mm. 10. Fender Modifications: rolled/pulled = none...yet 11. Picture.. from the side & down the side =
“If everything’s under control, you’re going too slow”. - Mario Andretti Last edited by s14dr1ft3r; 04-13-2006 at 11:58 AM.. |
#40 |
1. S13
2. Tokicko Blue Struts with some brand spring (came with car) 3. 15x7 4. Konig Rewind 5. +/- 0 6. No Spacer 7. 195/60 8. N/A 9. OEM brakes 10. No Fender Mods 11. ![]() ![]() ![]() It will be lower soon enough, for now the handling of the current setup is fine. |
#41 |
![]() Join Date: Jun 2005
1. S13 FB
2. Megan Coils 3. 15x7 4. Enkei Mesh 5. +/- 0 6. No Spacer 7. 225/50 8. Don't even know ![]() 9. OEM brakes 10. No Fender Mods 11. (SE's in the rear) |
#42 |
Bringing this thread from the dead, I think a MOD should clean it up and sticky it. Anyways here it goes
1: S13 2: Megan Coilovers 3, 4, & 5: 17x8 +35 Zigens FN01R 6: 10mm front and 15mm rear spacers 7:235 40 17 Azenis ST115 all around 8: -2 camber front & -1 rear 9: Clears Q45 and Z32 brakes 10:rears rolled I did not have the tires for the rear when I took the pics, but they look as flush IMO as the front Here's a pic from the side so you could tell my ride height more or less Last edited by AmuroRay555; 02-23-2006 at 10:30 PM.. |
#43 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
1. S14
2. Megan Streets 10. Rolled fenders Everything else, see below. FN01rc 17x9 +15 (+0)(15mm spacer), 215/45/17 17x10 +12 (+7)(5m spacer), 235/45/17 Sport Max 962 17x9 +35 (+0, -5) (35mm spacer front, 40mm spacer rear) 215/45/17 all around Work Emotion Cr Kai 18x9.5 +12 (+7, -3) (5mm spacer front, 15mm spacer rear) 225/40/18 all around SSR Professor SP1 17x9 +6 17x10 -1 235/40/17 all around
#44 |
1. S13/S14/S15 = S13
2. Suspension Setup = Zeal B6 (clears front coils by about 4~5mm) 3. Wheel/Rim Size front & back = 18x9.5 all around 4. Brand of Wheel/Rim = Silver Work Emotion XT7 5. Offset front & back = +12mm all around 6. Spacer Size = none 7. Tire Size front & back = 225/40/18 falken fk451/fk452 8. Alignment Specs = front -2ish, rear -3ish 9. Clear Zbrakes & what size brakes = clears tt z brakes by 2.25" 10. Fender Modifications: rolled/pulled = fronts rolled and hammered inner fenders, rear rolled and pulled 5mm 11. Picture...= |
#45 |
![]() Join Date: Jan 2004
2. Suspension Setup = Megan Track Series 3. Wheel/Rim Size front & back = 17x9 17x10 4. Brand of Wheel/Rim = Fno1rc's 5. Offset front & back = +15 front +35 rear 6. Spacer Size = 5mm on front to clear coilover (did not need the spacer on my d2's) 7. Tire Size front & back = 225/45/17 front (now a 235/45/17) 245/45/17 rear 8. Alignment Specs = front 3.0 rear 2.5 Zero toe 8 degree's of caster (stops front rubbing at full lock) 9. Clear Zbrakes & what size brakes = Will clear any type of brakes (3 inches over Z32's 10. Fender Modifications: Hammered lip up but no pull at all 11. Picture...= And just ro show how low i am, look at the top of the front tire to the fender. |
#46 |
![]() Join Date: Jul 2003
1. S14
2. Apexi' N1 Type V 3. 17x9.5 all around 4. Work Emotion XD9 5. +17 all around 6. spacers are weaksauce 7. Falken GRB FK-451: 235/40/17, 245/40/17 8. -3 deg camber F, -3.5 deg camber R, slight toe out front, slight toe in rear 9. Clears my q45 front brakes, supposedly will clear 300ZX brakes 10. hammer rolled front, roll and pull in rear (minor pull, but still took work) Comments: If I had to do it again, I'd get 235/40/17 in rear as well, should require less neg camber and no pull. Next wheels will be 17x9 +22 for track use. Pix: |
#47 |
![]() Join Date: Apr 2006
1. S13/S14/S15 = S13 hatch
2. Suspension Setup = Megan Racing street coilovers 3. Wheel/Rim Size front & back =19x9/19x10 4. Brand of Wheel/Rim =SSR Vienna 5. Offset front & back = 9+6/10+0 6. Spacer Size =N?A 7. Tire Size front & back =215/35, 225/35 8. Alignment Specs =Toe,Caster is zero and massive 7 degrees of camber 9. Clear Zbrakes & what size brakes =Yes, its stock 10. Fender Modifications: rolled/pulled =flat rolled and slight pull (few MM clearance) 11. Picture= ![]() ![]() Herb [email protected] |
#48 |
![]() Join Date: Mar 2002
Well maybe it should have been bumped, not enough people search for this shit...
Updates! 1. S13 2. STANCE GR+ Pro (F 175mm 9k R: 200mm 7K) 3. Gram Light 57S F 17x9.5 +12 (-3 with spacer) 235/40/17 Gram Light 57S R 18x9.5 +12 235/40/18 Work Equip White R 18x10 +18 235/40/18 8. Camber F = 3.5 R = 2.1 Toe = 0 Caster = 7 degrees 9. Stock Brakes 10. Origin 20mm front fenders, Origin 30mm rear fenders, pushed in for about 15mm of overfenders
PROCEED Grip Gambler |
#49 |
![]() Join Date: Mar 2003
1. S14 Kouki
2. Suspension Setup = Yashio Factory Spec Plus Coilovers (F-10kg/ R-9kg) Nismo Bushings Kazama Tie Rod Ends Tein Tie Rods Kazama Member Rigid Collars Tanabe Rear Upper Control Arms Cusco OS-ALC Strut Tower Bar (Front) Cusco CB Strut Tower Bar (Rear) Nismo Power Brace 3. Wheel/Rim Size front & back = (Front - 18x 8.5/ Rear 18x 9.5) (only 17lbs. each) 4. Brand of Wheel/Rim = Advan TCII (Gold) 5. Offset front & back =Front +25/ Rear +29 6. Spacer Size = None as of yet but I may get Yashio Factory 5mm all around... Tire is super close to the Coilovers right now. 7. Tire Size front & back = Advan Neovas AD07 225/40R-18 (Front)/ Yoka ES100 265/35R-18 (Rear) 8. Alignment Specs = None as of yet... still working on Suspension parts. 9. Clear Zbrakes & what size brakes = Yes... Skyline R32 Sumitumo Calipers (The Biggest Stock Caliper without going Brembo). Rear is Full Z32 w/ Drum e-brake. 10. Fender Modifications: rolled/pulled = None yet... I will be rolling the front and rear for better clearance. 11. Picture.. from the side & down the side = Front Rim & Brake Setup Rear Rims and Brake setup... you can see there is plenty caliper clearance. Side Angle shot from the front... Peace Drew
URAS |
#50 |
s145 wheel spec
1. s14
2. JIC FLT A2 D1 spec 3. 18x9 F 18x10 R 4. Wisesport($900 each new) 5. +23mm +23mm 6. +20mm front only 7. 225/40/18F 255/35/18 8. -3F -1R 9. spacer to clear z brake 10. front 10mm s145 IC conversion fenders rear levi spl custom roll http://www.jspec.com/jspecs145ver2.html scroll down click on photos for enlargement
Nissan Japan: "road to happiness has many curves" Jdmlivin: "Jdm is dead, the yen is crazy"
#51 |
2. Suspension Setup = Tanabe Sevens + pretty much all the battle version suspension arms 3. Wheel/Rim Size front & back = 17x9.5 4. Brand of Wheel/Rim = CST D-Spec 5. Offset front & back = +15 all around 6. Spacer Size = n/a 7. Tire Size front & back = 215/40/17 all around 8. Alignment Specs = -2.5 9. Clear Zbrakes & what size brakes = clears z brakes 10. Fender Modifications: rolled/pulled = rear is rolled 11. Picture.. from the side & down the side = |
#52 |
2. Suspension Setup = K Sport Kontrol Pro Coilovers 3. Wheel/Rim Size front & back = 17x8 4. Brand of Wheel/Rim = König Privat Fahren 5. Offset front & back = +20 6. Spacer Size = none 7. Tire Size front & back = 245/40/17 F&R 8. Alignment Specs = Stock F, -2.2 R 9. Clear Zbrakes & what size brakes = Clears 300ZX 30MM 10. Fender Modifications: rolled/pulled = none 11. Picture.. from the side & down the side =
#53 |
![]() Join Date: Dec 2004
2. Suspension Setup = Tein super drifts, Peak Rucas and no name toe rods 3. Wheel/Rim Size front & back = 18x9 and 18x10 4. Brand of Wheel/Rim = Volk GT-C face2 5. Offset front & back = +38 (+8 w/spacer) front, +5 rear 6. Spacer Size = 30mm in front (project Kics w/hubcentrics) 7. Tire Size front & back = 225/40, and 245/40 Falken 512's 8. Alignment Specs = unknown as of now, "eyeball alignment" 9. Clear Zbrakes & what size brakes = clears z brakes 10. Fender Modifications: rolled all around, gonna pull rear tomorrow 11. Picture.. from the side & down the side = Need to pull it tomorrow and work on the height
95' Gold Zenki - STOLEN!!! / recovered!!! Last edited by bleach8484; 03-01-2007 at 08:31 PM.. |
#54 |
![]() Join Date: Oct 2006
Trader Rating: (163)
1. S13/S14/S15 = S13 with aftermarket 5-lug
2. Suspension Setup = Cusco Zero 2E's 3. Wheel/Rim Size front & back = 18x8.5 and 18x10 4. Brand of Wheel/Rim = WedsSport TC-005 5. Offset front & back = Front +32 Rear +44 6. Spacer Size = None 7. Tire Size front & back = Front 245/40 Rear 275/35 8. Alignment Specs = 9. Clear Zbrakes & what size brakes = Front Stoptechs Rear Z32 10. Fender Modifications: rolled/pulled = Rear Rolled 11. Picture.. from the side & down the side = Last edited by Broadfield; 03-01-2007 at 08:08 PM.. |
#55 |
1. S13/S14/S15 = S13 w/ S14 5 Lug
2. Suspension Setup = Stance GN Pros 3. Wheel/Rim Size front & back = 18x9 and 18x10.5 4. Brand of Wheel/Rim = Fabulous Expand 5. Offset front & back = Front +8 Rear +18 6. Spacer Size = None 7. Tire Size front & back = Front 225/35/18 Back 245/35/18 8. Alignment Specs = Front Spindle mount full negative, with pillowball at 0 Degrees. Rear - 2 to 3 degrees of camber... using a peak performance uca to to push wheel out for clearance 9. Clear Zbrakes & what size brakes = Clears front and rear Z32's 10. Fender Modifications: rolled/pulled = Front: Pulled/Rolled/Hammered Rear: Pulled/Rolled/Hammered. Notes: I have about 2 mm of clearence with the rear inner fender and zero on the outer... tire wore away inner and outer sides of the tire. Extreme fitment.... I dont recommend this set up on stock fenders ![]() Front fits great due to the wicked tire size provided by Toyo (t1-rs), not many companys make that tire size... so the vehicle will go low.
@woooster on instagram |
#56 |
1. S13/S14/S15 = s13
2. Suspension Setup = tein flex's w/edfc tein tie rods 3. Wheel/Rim Size front & back = 17x7f 17x8r 4. Brand of Wheel/Rim =wedsports 5. Offset front & back =+32 all around 6. Spacer Size =none 7. Tire Size front & back =225f 245r 8. Alignment Specs = -1.5 camber iirc 9. Clear Zbrakes & what size brakes = yes. stocks 10. Fender Modifications: rolled/pulled =none 11. Picture.. from the side & down the side |
#60 |
back from the dead...keep this alive, more input plus a sticky would be nice....also amazing looking at so many of your cars 2years ago to now...big changes
specs from the old ride all this getting swapped over this week 1. S13/S14/S15 = S14 2. Suspension Setup = tanabe sustec pro seven << going on today 3. Wheel/Rim Size front & back = 17x9 17x10 4. Brand of Wheel/Rim = 5zigen fn01r-c 5. Offset front & back = +15/ +12 6. Spacer Size = 7. Tire Size front & back = 245/45/17 255/45/17....wheels came with them 8. Alignment Specs = 9. Clear Zbrakes & what size brakes = r33 brakes up front stock rears 10. Fender Modifications: rolled/pulled = rolled 11. Picture.. from the side & down the side = |
