![]() Join Date: Jun 2003
offset question for s13
5 lug s13
lowered on megan racing front: 17x8 +28 offset with 215 25 17 rear: 17x9 +27 offset with 225 45 17 pretty low, will these be clearing coilovers, z brakes and most importantly, be flush pretty sure spoke design will allow z brake clearance, not so sure about my coilovers because megan racing has a lot of problems. |
The front wheel in that pic looks to be past the fender a little. I'd say that is a +20 or so in front.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
![]() Join Date: Jul 2003
Actually in the pic it is a
17x9 +15 To get that flushness out of and 8 you need -10 at least. I think he meant 215/45 not 215/25. I am running a 215/45 on a 9 inch wheel, its fine. |
#8 | |
![]() Join Date: Jan 2004
So whats the point of a nine inch rim if you are going to run tires made to fit a 7 and a half inch rim properly? |
yeah i meant 215 45 17
i just want big rims, and i have those tires laying around from when my rims were 4 lug. ok anyways, i decided to just order my rear rims. the setup is like this. 17x9 +27 with 235 40 17 falken st115, im going to try to fit this in the front, and depending on how it fits, i might just use these for the front and get something else for the back, if it's too crazy, then i'll just slip these into the back. i really hope they fit good in the front, cuz i might run some fno1rc by 10s in the rear. |
Retired General
why not just run those wheels in 17x9 +17 all around?
![]() Join Date: Nov 2004
hey guys, for the rear, i wanted 18x9.5 and for the rim that i want, apparently it only comes in 9 or 10. so i want the 18x10. i knew my offset for the 18x9.5 which was +30. what would the equivalent be for 18x10?
