Old 08-23-2014, 07:32 PM   #1
s13_st
s13_st is an unknown quantity at this point
Bad alternator?
I recently installed an sr20det, I have a new odyssey p 680 battery. The needles on the gauges jump like crazy when I shift, car has rough and high idle, when I turn on the accessory (headlights, etc.) Everything flickers and car dies a couple seconds later when I'm not driving. Is this a bad/weak alternator issue?
s13_st is offline   Reply With Quote
Old 09-03-2014, 10:30 PM   #2
Mildviolence
Mildviolence's Avatar
Mildviolence is an unknown quantity at this point
Sound's like it. Just take it in and get it tested.
Mildviolence is offline   Reply With Quote
Old 10-22-2014, 03:33 AM   #3
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
Sounds like you might have a grounding issue as well. id check all of your ground and clean all your terminals and battery posts.
omgwtf is offline   Reply With Quote
Old 10-22-2014, 04:41 AM   #4
97nismo
97nismo's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
That battery isn't strong enough from my experience...I upgraded to miata battery and it helped. You really need to get a full size battery and move it to the trunk. Also get a multimeter crank the car and see if you are staying above 12 volts when you turn on the lights if it drops then alternator isn't charging. If your dash lights up brake and battery then it could also be a good idication it's the alternator.
If it's a ground I can't help you...if you are running an atmospheric bov on a stock sr then that could explain your dying and idling funny issue
Feedback:
#/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
