widebody question
i'm ordering origin 30mm widebody (pulled fender look) and i have MB battle 17x9.5 +15.. my question is what size spacers will i need to make the rims flush? i don't want to run crazy camber either.
20mm? |
this is going to sound crazy but you would probably need a 50mm spacer. this is my specs with the same overfenders as yours: sportmax 18x9.5,+35offset. with 50mm spacer its still not "hellaflush" but works. but since yours is +15 it will be great. so if you want to measure compared to mines: 9.5 x 25.4 = 241.3mm, minus 35mm plus 50mm because of spacer. 265mm overall is going to be from the outside hub to lip of rim. now you can measure from your hub to the end of your fender and see what number that is, then add 30mm cause of the overfender. mine is about 2/5 of an inch away from fender to rim.
#4 | |
![]() Join Date: Dec 2010
) at all, and believe in proper alignment specs for performance, but still want to fill out the wheel openings effectively |
damn 50mm really? my friend has 50mm over fenders and i'm pretty sure he has 50mm spacers and hes flush on the same rims as me, but i'll double check, thanks for the reply man!
![]() Join Date: Nov 2010
Trader Rating: (45)
![]() Feedback Score: 45 reviews
hate to bring up a very old thread but i cant find help.
i was wondering what size of spacers did you use? heres my problem. i have 30mm spacers on 18x9.5 +15 mb battles. i cant find 40mm widebody. only options i have is 30mm widebody. but i dont want it to rub. i dont want krazy camber either |
![]() Join Date: Apr 2010
if your running 30mm spacers, why not ditch them for 15mm or 20mm spacers. Seems like a pretty freakin easy answer to your question. Now stop being an idiot.
#14 | |
Trader Rating: (45)
a finger or 2 gap will be fine. you think i could bow out the 30mm to the point it doesnt rub? |
