#31 |
Buffed my lights today
MRP Manufacturing |
#34 |
Haha, practice makes perfect. Had some time the other day to get rolling on this second motor build. Fully built. Got new freeze plugs, painted, crank installed. Eagle rods, supertech 9:1, arp, clevite bearings, cometic. Jesus file fitting rings is a bitch, may just pay the machine shop around the corner to do it.
Painted this bay for my buddy with help from my mentor
MRP Manufacturing |
#39 | |
Got my Pistons/rods in today. File fitting rings was a bitch. There are 9 s-chassis at the shop right now, not including mine. 6 s13's 2 s14's 1 s14.5 And my bro dude (the car on the lift) took second at the local comp
MRP Manufacturing Last edited by KAT-PWR; 12-21-2015 at 06:33 PM.. |
#40 |
fuck yea, nice paint job. Even thou it's not in a booth with proper equipment, not bad at all! those clearcoat runs, u can cut it down as flat as u can when it's still soft. then block it down with 600 grit sand paper with soapy water. Good job man, keep em coming.
#41 |
Wire tuck all worked out great, finally got to test my lights. Just need to button the interior back up. Been working on head porting and polishing.
MRP Manufacturing |
#43 |
I just have the low beam wiring ran to the low beams, and highs to the high beams. I didn't do a relay to make them both come on at the same time yet.
MRP Manufacturing |
#44 |
Looking good man!
#45 | |
![]() Join Date: Jan 2014
#46 |
Yes that's the one
MRP Manufacturing |
#48 |
Found some secret sauce for $60 local
MRP Manufacturing |
#49 |
Here's the relay method if you haven't already seen it. Did it on my car on the weekend and it works flawlessly
http://nissanpure.com/forums/viewtopic.php?p=59 ![]() |
#50 |
Nice thank you man! Hippo sleek skirt. Probably going to run the hippo sleek rear bumper.
Need to decide what color to paint the car
MRP Manufacturing |
#51 |
Sorry night shots only. Gotta finess the glove box wires (Fuse boxes are in there along with a fusebox for all the gauges)
Going to pull cluster and do the needle red/orange LED cluster lights LED's in DCC Molded gauge pod 62mm to be mounted on A pillar (sucks just found out one of the bulbs is out)
MRP Manufacturing |
#52 |
Got the glove box cleaned up a little
MRP Manufacturing |
#53 |
S14 vs s15 seats to try and put it to rest.
MRP Manufacturing |
#55 |
Thanks man, got the car running/driving this week. Got my head put together for my other motor
JWT valve tool is a beast for re-assembly. Took about 45mins. Water tested the valves, no leaks. Will re-test with gas before putting it back on. The intakes leaked when they were just set in so I was a bit worried I didn't lap them enough, but after putting the springs in they didn't leak a drop.
MRP Manufacturing |
#56 |
Wow really cool thread. I always see you post and have meant to check this build out. Keep up the work. I really want to tuck my harness and bring in the relay boxes like you did.
#57 |
Throwing in this nismo 2 way I got for $60 lol. Guy thought it was an s15 diff because it was in an s15 pumpkin but it wasn't.
MRP Manufacturing |
#59 |
Neukin catch can, I don't believe they make them anymore
MRP Manufacturing |
#60 |
New manifold on
Waiting for new downpipe [imtp://i166.photobucket.com/albums/u116/waxball88/ED6DA396-C144-4687-B2A4-700C33A9C27C_zps0gwppeiy.jpg[/img]
MRP Manufacturing Last edited by KAT-PWR; 05-10-2016 at 04:03 PM.. |
