What parts would i need to replace?
i just bought this s13 and wanted to know what exact parts i would need to replace from this pic. i know the the whole entire thing is gone but other than this the car has very minimal rust. noob question but what is the name of the exact part that rusted off completely thanks. any other advice would be greatly appreciated
https://imgur.com/AwI2LH0 |
![]() Join Date: Mar 2007
that’s your lower radiator support. hope no one has driven the car in this condition...
you’ll need a lower radiator support (assuming the frame rails aren’t rusted to shit as well), probably tension rod brackets, a tetanus shot, maybe struts and a trip to the frame puller if it’s been driven around like that. a better option would be to get your money back and buy a less rusty pile of shit
![]() Join Date: Jun 2003
Trader Rating: (129)
good lord. if the rad support is THAT rusted out, chances are a lot of the REST of the chassis is rusty as well.
the rad support is replaceable as long as you have a decent fabricator at your disposal. http://www.chairslayer.org/products/s13-radsupport https://thehumbleengineering.com/sho...-nissan-240sx/ there are reinforced ones available too, or you could remove the entire front radiator support and go tube frame, but that's a large amount of fabrication |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I would check to see how far that rust goes before investing in fixing that, chances are if is that is rusted so is your frame rails, floor boards, and even rear sub frame...
might not be worth fixing. .02
![]() s14 kouki ka-t Last edited by turbo2nr; 04-16-2019 at 11:23 AM.. Reason: grammar -_- |
