07-20-2009, 02:24 PM | #1 |
BC stage 3 cams tuning
Hello fellow Zilvians!
I've got a fully built sr20 engine with stage 3 cams from Brian Crower(272/272). I'd like to have some advice on how to tune them, overlap and everything. For now I'm at 2 degree BTDC on the Intake and 6 ATDC on the exhaust. But when I turn my engine by hands, I can hear some of the compression going in the exhaust(which in fact is very low(120 PSI on all 4, not even 1 psi difference on each)) I drove the car for about 500 miles since I've built it. Here's the tag that came with the cams. And oh yeah, i've got the valve springs! So if anybody has got any experience with those cams, it would be appreciated if they can share with me! Thanks a lot for your help Frank |
07-20-2009, 11:23 PM | #2 |
[off topic] Can you post your full setup as far as motor and drive train? How high are you looking to rev this thing?[/off topic]
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings?? |
07-21-2009, 04:42 AM | #3 |
Engine
Sr20det Blacktop Garrett Gt35R .63 Ar Dual Ball Bearing Turbo Tial 44mm Wastegate CP Piston 86.5mm 8.5:1 (Overbore 0.5mm) Eagle H-Beams Connecting Rods ARP Head Studs Kit ARP Main Studs Brian Crower Camshafts Stage 3 Spec 272/272 Brian Crower BC Valve Springs / Retainer Kit Hks Ajustable Cam gears Hks Fuel pressure regulator Hks Fuel Pressure Gauge Hks Hi-Power 3.5" exhaust Circuit Sport SS Turbo Lines SR20DET Main/Rods/Thrust Bearings Sard 850cc Injector + Spacer Walbro 255 Lph fuel pump Custum SS Fuel Line Timing Chain kit + guides Oil Pump Assembly Cometic Metal Head Gasket Water Pump Full Engine Gasket Kits Nismo Thermostat Nismo Motor & Tranny Mounts kit Greddy Intake Manifold Plennum Greddy Type R Blow Off Valve Greddy Cooling Plate Greddy Oil Pan Greddy Rocker Arms Stopper Greddy Oil filter relocation kits Full-Race top mount turbo manifold coated 1300deg Full-Race 3” Upper Top mount Adaptor Downpipe Blitz 3" Downpipe Blitz LM Front Mount Intercooler Blitz Lm Intercooler piping kit Blitz Radiator cap 1.3kg/cm Blitz Radiator Hose Samco Radiator Hose Sard Torque Control Valve SplitFire Coil Pack Koyo 3" Aluminium Radiator B&M Short Shifter Cusco Oil Can can Spec Stage 3 clutch kit AEM Filter kit DriveshaftShop One piece Alluminium Drive shaft Dual Electric Fan + Full Race Custom Plate Footwork / Handling Cusco Zero 2 Coilover kit + Camber plate Kaaz 2 way Lsd Energy Suspension Bushing Polyurethane Kit Tc Sportline Strut Bar Front/Rear Ichiba 5 Lug Hub conversion Z32/Skyline Brakes -Front: 30mm Aluminium Calliper 4 pistons -Rear: 18mm Aluminium Calliper 2 pistons Brembo Rotor 11” Drilled+ Projet Mu B-force ceramic Pads Russel SS Brake Line Work Emotion Cr Kai Wheels Front: 17 x 9 +17 With Yokohama Avs Sport 235-40-17 Rear: 18 x 9.5 +12 With Yokohama Avs Es-100 245-40-18 Greddy tuners Lock Nuts Muteki tuners Lock Nuts Interior/Exterior D1 B-magic Body Kit Origin Lab Carbon Hood 180sx Kouki front Bumper Light Cristal projector Headlight D-Max Cristal Tail light Black Leather Rear Seat Bride Brix II Seats Bride Type MO seat brakets Nardi Torino Steering wheel Works Bell S13 Hub NRG innovation Quick Release Hub Gen 1.5 Momo Pedal set Momo Shift knob Megan Racing Pillar Gauge Pod Custom Alluminium Center gauge pod Custom Switch Panel Electronic 180sx Jdm Cluster Apex’i Power Fc D-Jetro + sensor kit Apex’i Turbo timer AEM Uego Wideband AEM Tru-Boost Electronic Controller kits AEM Alcool/Water Injection Kit Defi BF Amber Oil temp Gauge Defi BF Amber Water temp Gauge Defi BF Amber Oil pressure Gauge Defi Multi Link Controller Optima Red top battery Alpine Type R 10” Subwoofer 4 x Power Series Jbl speaker Jbl Bpx 500.1 Ampli Pioneer premier DEH-P490IB Head unit 2way Security System |
07-22-2009, 10:06 AM | #4 |
i have a similar valve train with 272/272 and my compression test was around 115-120. Leakdown was less than 3% on all cylinders. On another topic, someone mention high lift/high duration cams could lead to showing lower compression.
09-26-2009, 05:33 PM | #5 |
I just bought those same cams for my sr20 but I have a stock bottom end. I was also wondering about tuning am I going to need NIStune or something similar or can I get my stock #63 ecu tuned? Sorry if its a stupid question Im kinda new to the whole tuning thing.
