this is getting REALLY annoying now. help me * pic included for better understanding*
hello all.. i removed my upper and side chain guides... and i STILL get the rattling WTF? ...
now i wanted to know if the lower chain guide is causing this?... but i dont' think that's the problem ... the thing is the rattling is only audible when the A/C is on... WTF? and it sounds JUST like if the guides are still in there... WTF? :hammer: so i checked my tensioner if it was still usuable and it compressed and everything .. ARG~~ so can the tensioner even tho is compresses and moves that it is causing slack in the upper chain to hit the valve cover? ... but ONLY WHEN THE A/C is on? it seems like when there is more load on the engine, the rattling starts to appear... can anyone HELP ME?~ ... i hate this... oh and btw ... i have a ka24de thank you ~ |
oh and i can hear it the most with the a/c on an at around 2-3 rpm in 3rd gear... in the 30 - 40 mph range... thank you again
![]() Join Date: Dec 2002
A/C would have nothing to do with the chains, your noise is somewhere else.
Sounds like the compressor clutch is loose or bent, making a noise when engaged. You're just hearing it due to resonance through the block I bet. Go out under the hood with the A/C on and unplug the compressor, see if it stops. If so, plug it in and use a stethoscope to pinpoint the noise. |
well... hum...
maybe... but the thing is .... will it still make the sound after i turn off the a/c? and it tends to be LOUDER under load also .. this is what i did... i had the a/c on and then it started to make the noise so ... i turn it off and still it makes that chain guide rattle sound... ( this was under load... driving not at idle ) and sometimes i can hear it without using the a/c ... i mean like i press the clutch and play with my engine sometimes.. * i know shoot me * like i dont' rev hard.. i just rev to like 3 - 3.5 k just to hear my new exhaust... and i can hear the rattle kick in sometimes.. ***** btw... it doesn't rattle at idle so i can't really pinpoint the noise at idle **** so what do you think ? anyone ? pleas ehelp..... aRG thank you |
so really the question is how do u know it is the chain guide or if it is the tensioner gone bad....if u cant hear it at idle..have u tried revving it to 3500 or something until u do heara noise....but how does it really sound though??? give more details.....
it sounds just like when the chain taps on the chain guides...
just ... they are not there.. anymore and yea.. i want to know if the tensioner is bad... will it make this sound? ... and well... when i just rev it to 3500 it doens't make a sound but when i fluctuate the rpm's fast it starts making the sounds... |
![]() Join Date: Mar 2003
is your oil low? low oil pressure will cause slack chain.
if the tensioner is bad, the chain will be slack and make rattling noises. there are actually two tensioners... number 18 is the lower chain tensioner. i've never heard of one going out, but i suppose it's possible. btw the lower chain guide is necessary and you shouldn't remove it. imo first step is to get a mechanic's stethoscope and pinpoint the noise. |
just changed the oil with 4 quarts mob 1 syn...
maybe too much oil ? will it cause noise? and the sound is definitely coming from the top so i guess ... i should try and change that then ... but ... btw... thanks aznpoopy anyone else ? |
#10 | |
Directly from above: "but ONLY WHEN THE A/C is on?" So which is it? |
#11 | |
#13 | |
it STARTS to rattle after i turn on the a/c and then the rattle dies away after i turn OFF the a/c ... but i can still hear it while shifting aznpoopy ... i will check my valve cover this weekend to see if anything is up ... and la phantom hopefully it won't be but i will be checking that also thanks alot guys for the help~~~~~ props to all of you ^^ |
First
remove all belts and start your car, check for noise add one belt at a time, start your car after. Be carefull, the water pump will not be functional, DONT overheat the car. 30 to 45 seconds of idle time is enough. 240sx AC are noisy. Its a design "flaw" Even the FSM says so. They are louder as the pressure and temps get higher. Also, the AC belt tensioner makes some scraping noises when dirty or the bearing is worn. |
trust me... it's not scraping... it's TAPPING but i'll check everything thanks again ..
Will quote my FSM regarding AC compressor
In my 93 fsm page HA-11 #3 A "claking" sound may occasionally be heard during refrigerant charge......etc If your car do NOT make the sound a idle with AC off, I am sure that your chains and guides are ok. |
#17 |
but with the a/c off i do hear it at times so ... but thanks for that heads up ... and btw... i have a 95 hehe
thanks again |
#18 | |
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
...ever figure it out?
#/f/sale-items/24807...-stuff-fs.html |
#19 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Hmm, I have a similar problem that ive been lazy to look into. After I took the top guides out, I have a clanking/knocking under certain loads. I remember not being able to move the tensioner when I took the guides out so I figure its that. I guess I should stop being lazy and check my valve cover for marks.
#21 |
![]() Join Date: Feb 2006
My friend's S13 with a KADE was exhibiting the exact same symptoms. It turned out to be rod knock. It kicked the bucket while i was driving it up a bridge (under load). The #4 rod exited through the oil pan, while the cap took the scenic route through the side of the block
We found the connecting rod at the side of the road where it blew up. Those are pieces of the engine block next to the rod. Anyway, make sure its not rod knock, so you can still salvage some parts of your motor. |
#22 | |
![]() Join Date: Apr 2004
![]() ![]() Feedback Score: 2 reviews
But honestly yeah, Id check for oil leaks, and keep a close eye on oil level |
#23 |
if its at idle its timing chain (replace your chain tensioners)
If its all the time, Good chance its rod knock :P
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole. |
#24 | |
![]() Join Date: Aug 2004
95 Lexus SC300 5-speed -DD pimp car 92 Nissan 240sx base coupe -clean KA24DE swapped in -GTIR T28 -Big FMIC -565cc STi Injectors w/ Z32 MAF -J30 VLSD w/ subframe spacers -RPS Max clutch -3" turboback -PLMS Daughterboard on modded ECU |
