altenator not charging,
ok i just did an sr20 swap and id drive around a bit and all of the suddent my radio would cut out, and my dash light for the battery would start blinking the higher i revved it could go out, but at idle it would come on, i charged my battery and it holds a charge, i changed alternators to the ka alternator and it does the same thing, i get a voltage that drops from 12 slowly while the engine is running i think my belt might be the problem, the ribs are beat apart (turns out before my alternator bracket wasnt bolted down) how much play should be in the belt.? i dont hear the belt slipping though, but before is slipped like a mofo
Definetly take it in to autozone to have them test it.. its free.. !
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
check the alternator fuse... i think its the 75amp one.... i blew two of those with the same symptoms...
http://www.thenismoshop.com |
yea i checked that fuse, i got a new belt, my old one had all the ribs completely sheared off, basically what i was doing was using the ka waterpump pulley which has a different offset then the sr20 wp pulley. so that in conjunction with my bracket being loose caused me to chew up belts, ne how i got the new belt and it runs great now, squeals like crazy though, its tensioned im running somewhat of a rigged tensioner setup. if anyone has a oem sr20 w/p pulley ill take it off your hands.
