Bee*R limiter install?
ok i have everything hooked up correctly except the green wire (ignition) signal it is reading the rpm's cause when i hit were they are supposed to be the light flashes and even with the launch control i have it hooked up to the e-brake does anybody know whta color wire the ignition signal is this is the only thing i can think of?
s13 redtop |
