Old 12-01-2008, 07:38 PM   #1
Veltall
Veltall's Avatar
Veltall is an unknown quantity at this point
1jz misc
sorry this isn't about a 240. but who knows if an r154 tranny bolts up directly to 1jz w/o a different bell-housing?
Veltall is offline   Reply With Quote
Old 12-01-2008, 10:29 PM   #2
kid270r
kid270r is an unknown quantity at this point
If you get the:
Soarer R154 your all set
MKIII Supra (1jzgte) R154 all you need is the shift extention
7MGTE R154 you need linkage extention and the 1jz bell housing do to the fact that this trans doesnt bolt to a JZ motor... It was originally bolted to a M motor.
Here is the tricky part. You need to use a 1jz R154 flywheel
BUT you need to use the 7Mgte clutch when you do the 1jz or 2jz swap...
kid270r is offline   Reply With Quote
Old 12-29-2008, 02:18 PM   #3
dillusion13
dillusion13 is making a name for him/her selfdillusion13 is making a name for him/her selfdillusion13 is making a name for him/her self
It bolts up, that's the tranny that usually comes with that motor.
dillusion13 is offline   Reply With Quote
