18mm titania o2 sensor
Does anyone know of an option for a 18mm titania sensor that can replace the small factory sensor used with the 62 sr ecu My downpipe has an 18mm bung and my wideband is really really rich at idle. Mid 12s. Mechanical timing is spot on. No o2 sensor currently. Ignition timing at 15*. Stumbles on take off. Only code is 34 for knock sensor.
