s14; my car sat for about a yr.. i have megan street coils and the steering wheel shakes when on the freeway 60-65 mph, possible that tires arent balanced because of sitting for so long or alignment?? im clueless. thaks in advance
you guys need to learn how to fix flat spots instead of just buying new ones and wasting money.
how to fix flat spots on your tires lol ( fox body burnout ) - YouTube dont forget to rotate and repeat |
They probably just need balancing. I have tires still on my car after 18,000 miles, and they had sat for 8 years flat before I got the car. Haven't even balanced them, but no vibrations even up to 115+mph
Just wanted to share my experience i know its an ancient thread.
I have a 98 S14 originally an auto car has 79K original miles.. had 68k when i bought it and the problem was there then too. I inspected the entire suspension all the ball joints and tie rods seemed great, tension rod bushings were leaking so i replaced them thinking that was it.. It wasnt. Had tires and wheels balanced, it was a bit better but still not right.. Anyway, my car is in great shape wasnt beat low miles etc.. Didnt think the steering rack bushings were bad, however that ended up being the cause, the rubber is very soft and the DS bushing was starting to come apart.. (couldnt really tell upon installed visual inspection) I replaced the DS with an energy suspension bushing and the other with a Nismo bushing, very happy with the results.. i suggest replacing them if you have a shake, even if they appear to be ok. The job took a half hour.. very easy to do |
#13 | |
