Old 01-30-2012, 10:17 PM   #1
infinitedrift
infinitedrift is an unknown quantity at this point
engine ground
Need help on this, I have a ground going from the strut nut to the block which has been like that forever. I was getting jumpy revs so I decided to add another ground on the passenger side in the same place. I started the car and heard a loud "pop", now nothing won't turn on, No lights, no ignition..nothing.
infinitedrift is offline   Reply With Quote
Old 01-30-2012, 10:30 PM   #2
aled
aled's Avatar
aled is an unknown quantity at this point
Well.
Did you blow a fuse/relay? That's what fuses are for; safety.
aled is offline   Reply With Quote
Old 01-30-2012, 10:35 PM   #3
infinitedrift
Check the fuses there good but haven't done the relays yet. It might be a bad ground when I adjusted the wires, gonna check on that in the morning.
Old 01-31-2012, 02:30 PM   #4
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Check your ignition switch. Where did the losud pop come from?
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 01-31-2012, 03:05 PM   #5
infinitedrift
Not sure where it came from I was on they passenger side turning the key. What relay could cause this.fyi.. I have the battery relocated to the trunk.
Old 01-31-2012, 05:01 PM   #6
infinitedrift
Went to start it and it cranked right up...thanks guys for the help
