![]() Join Date: Apr 2008
Trader Rating: (44)
![]() Feedback Score: 44 reviews
10-20 dollar sale mostly
well i took apart an engine that i thought had rod knock, but it turns out that it had a spun bearing on one of the rods with that being said..
i have a front lower timing cover from a 96 kade 20 bucks.. next i have a kade flywheel still good just needs a resurface 20 bucks various parts in the box, crank pulley, timing chain and rails chain tensioner lmk what you need.. next is the rear main seal thingy haha 15 bucks Oil Pick up 15 bucks Not sure the name of this, its heavy as S*&t though haha 20 bucks crankshaft has that spun bearing but it should be fixable, and either way you can use it as a paper weight haha (sarcasm) this thing is like 50 pounds but since were in the U.S. and not england it will only cost you 20 bucks nnext is kade oil pan no dents at all just some scratches, 30 bucks haha sorry cant do lower than that, well maybe if you buy something else last is the actual block, looking to get 100 obo for this one its flawless Last edited by murffy; 04-06-2011 at 02:44 PM.. |
