#62 |
That s14 needs at least 740cc injectors with that turbo. Going to be ordering mine on the 1st and hopefully have dyno for you guys later in may
*Rio Empty Pockets Drift Crew*
#63 |
the 18g was great installed it about 3 months ago, till the seals went out on it. i should still have a warranty on it. it was installed by a ASC Cerf. Tech an have the reciept , an have the receipt from paypal when when i paid for the 18g turbo. so am i gona have any problems with an exchange? what i really want is the 20g so instead of sending me a 18g just send me a 20g an i'll pay the difference. thanks let me know if thats ok....!
#65 | |
![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
please send it with your original receipt and a copy of ASE cref. Thanks |
#66 | |
![]() Join Date: Nov 2007
![]() ![]() ![]() Feedback Score: 27 reviews
BX|Photo LS400 - Slammed | Fitted | Loud |
#69 |
yes i will have it sent as soon as i can with ricept.
it was a dd and a freqent difter i was running 15-20psi, daily at 10psi even tho i had a hicup i still like this turbo. like i said i dont want the 18g im going to run the 20g an just pay the difference! thanx AKA; MEL |
#70 |
![]() Join Date: Apr 2011
I wanna know more about the 20g! Im gonna order one tomorrow more then likely. Im looking for 400hp. I have the mods to do it except for turbo since my gt2871r went out. How does this turbo spool?
#76 |
right now all that is stopping me from ordering is , i cant seem to figure out if there are any aftermarket wastegates that can be bolted on to replace the stock 14.5psi one to run a lower number like 7 psi mabe.
really anyone? |
#77 |
so i got my turbo on and i only had to modify the turbo elbow and return line. it spools good!! and its feels better then my gt2871r i had. i didnt get to drive it much because it was late and im running a screamer pipe
plus i let it idle for 30 mins to get the turbo lubricated well.. |
#80 | |
yea cause your pm said you need the one same as riley , this is not the same one actually , we dont have the elbow anymore, we only have the one connect that intake, and that one is $25 shipped |
#81 |
![]() Join Date: Oct 2008
Ahh ohk well then what is different about the one riley had on his car?
So out of this kit you have the straight adapter, what do u recomend doing for the elbow then since the stock s13 sr20det one does not line up correctly? |
#82 |
![]() Join Date: Nov 2004
Mostly track, with some street driving on occasion.
You know that the wastegate that they supply can be adjusted right? Just like how the HKS one is adjustable for more or less psi, so is this one.
#83 |
really. for some reason i assumed that 14.5 was the lowest....so how low exactly can it be adjusted for?.....i really appreciate this info asap as im in the process of a full rebuild and planning my turbo setup...thanks.
#84 | |
Thanks |
#88 | |
if your elbow have a divider on the middle, you might need to trim the divider down. Thanks |
#89 |
![]() Join Date: Dec 2003
If these have nothing to do with the Forced Performance units that are discontinued then they look IDENTICAL; I have an FP unit. If they are, there is a slight fitment issue with the motor mount (mounted to a Tomei Expreme); you need to shave about 1/4" from it to fit down there. I did 394whp in 92*F on a Dynojet at ~18psi on a stock bore S13 SR20.
#90 | |
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
