Old 07-22-2011, 09:52 AM   #1
Evolutionz
Evolutionz's Avatar
Evolutionz is an unknown quantity at this point
Help
my recently acquired 240 is doing some weird shit.
Ive been converting it to a drift car, took out the seats etc.
I went to crank it up the other day, dead... just tick tick tick.
new battery and now it runs rough, like its missing an engine mount (it isnt)
slowly slowly decreasing in rpms til it finally dies (over a 5 minute period or so.)
I had a vacuum leak in the cold air intake, fixed it, but still the same. when I get it up in rpms it runs so so. it bogs on occasion, til finally it doesnt want to go anymore.
the cars new to me, everything looks okay, anything I can try? alternator maybe?
Evolutionz is offline   Reply With Quote
Old 07-22-2011, 09:56 AM   #2
bookoo
bookoo's Avatar
bookoo is an unknown quantity at this point
Check timing...had a ka do that to me the dizzy was turned all the way to retarded and wouldn't do anything but bog..check for more vac leaks...but the alt, start the car, then unhook the battery and see if it dies if so then of corse alt is bad. Otherwise look for more vac leaks...get some brake cleaner and spray it down and see what happens.
Also is the idle roaming..?
Iac valve if so.
bookoo is offline   Reply With Quote
Old 07-22-2011, 09:59 AM   #3
Evolutionz
Evolutionz's Avatar
unhook which part of battery? positive?
idle doesnt really roam, it just slowly decreases in short jumpy increments.
Old 07-22-2011, 10:07 AM   #4
Evolutionz
Evolutionz's Avatar
unhooked negative... car didnt change at all.
Old 07-22-2011, 12:17 PM   #5
driftxninja
driftxninja is an unknown quantity at this point
does your motor shake violently like its possessed by satan himself?
driftxninja is offline   Reply With Quote
Old 07-22-2011, 12:33 PM   #6
Evolutionz
Evolutionz's Avatar
Yes! Extremely bad
Old 07-22-2011, 05:20 PM   #7
Evolutionz
Evolutionz's Avatar
update, just got home, car cranks sounds like its misfiring and wont turnover. exhaust makes potato gun noises. no bueno.
ive checked nearly all lines, nothing is different.
Old 07-22-2011, 05:28 PM   #8
94spitfire91
94spitfire91's Avatar
94spitfire91 is an unknown quantity at this point
Spark plug wires in the right order? spark plugs and or wires may not be working properly. And if you hear a tick noise from your starter your starter is bad. Every starter has its solenoid and when it loses the ability to get power it makes that noise.
94spitfire91 is offline   Reply With Quote
Old 07-22-2011, 05:53 PM   #9
Evolutionz
Evolutionz's Avatar
the motor is turning, starter is good. should I just check plugs? like wtfff
Old 07-22-2011, 06:36 PM   #10
Evolutionz
Evolutionz's Avatar
I hear a whining noise when the key is on, doesnt go away. mean anything? it sounds like it wants to start, but no bueno.
also, extremely low oil... that cause it?
Old 07-23-2011, 08:18 AM   #11
Evolutionz
Evolutionz's Avatar
now the car for sure wont start, it rocks really really hard and wont get up past a 100 or so rpms. every so often it gets close to 500 and tries to officially start, then bogs down. there is still potato gun noises from the exhaust.
someone help!
Old 07-23-2011, 09:53 AM   #12
driftxninja
could be fuel injectors.
check that all your injectors are firing. make sure that your fuel pump is priming and working correctly. make sure you are getting spark and that your wires are dry.
ive had a similar problem with a previous 240 where i would be driving and one cylinder would randomly stop firing and the motor shakes horribly. it was the fuel injector stopped firing so the cylinder wasn't going.
so also make sure your spark plugs are in the correct order.
Old 07-23-2011, 09:54 AM   #13
driftxninja
you could have jumped timing also which is why it won't start now
Old 07-23-2011, 10:15 AM   #14
ericcastro
ericcastro's Avatar
first thing, make sure to get some oil in it right away !!
After that, do your spark plugs, car, and rotor.
Then go to auto zone and borrow the timing gun and buy some starter fluid.
try to get the engine started so you can check the timing.
(if not, no worries)
try and have someone turn the engine over for you and spray the starter fluid around different areas on the hoses, intake. If the idle picks up, you have a crack in the hose or intake.
also wouldnt hurt to take the fuel line out on the engine side, put it in a empty water bottle and try and turn the car over. is fuel going into the bottle?
where does this whine noise come from.
Old 07-23-2011, 06:47 PM   #15
Evolutionz
Evolutionz's Avatar
okay, on occasion of me manually trying to crank it, using the starter, it will sit pretty at 400 rpms for a few seconds once I stop, then fallonface...
just changed oil to full synthetic sexy ass pennzoil. spark plugs are on the counter, ran out of daylight. there is a tad bit oil in cylinder 3 from when I just redid the guide gaskets for the valve cover, the previous one was cracked and leaking... I dont think thats it. Im hoping it may be an injector, im scared its timing related.
I just read this #/f/tech-talk/384511...ls-like-2.html
and it seems like thats it. from what people have said, I think mine will be fuel related. the battery died super hard recently, and this is all derived from that, new battery, now running rough and now even worse, sounds like injector took a shit. are these expensive? should I upgrade? direct OEM? just curious.
When its light out Ill have more answers.
Old 07-24-2011, 08:59 AM   #16
Evolutionz
Evolutionz's Avatar
just got to work on it, pulled valve cover to look for weird shit, looks fine I suppose.
went to change the plugs, the second one from the front is stuck, I mean, Im a strong guy, and it clicks and wont budge, tried several different wrenches. da fuck... leave it and move on or what?
Old 07-24-2011, 09:36 AM   #17
!Zar!
!Zar!'s Avatar
Maybe you need to reinstall your interior.
Old 07-24-2011, 09:50 AM   #18
Evolutionz
Evolutionz's Avatar
changed the three plugs I could, now its starts and runs, but not good, still kinda like its been possessed by satan. and when I give it gas it gets all retard.
Im thinking this is fuel, or hoping so, having hard time getting the rail off, I have to run to work and will be back at 6 to finish getting injectors out to see if one is faulty.
if not what else could this be?
Old 07-24-2011, 12:16 PM   #19
ericcastro
ericcastro's Avatar
Get some pb blaster or some liquid wrench and keep drenching that plug. dont crank on it to hard, or it will break in the head or strip out the threads.
Soak it for an hour, give it a couple tries to jar it loose, not long pushes. If it doesnt give, keep soaking it.
You could tap the socket with a hammer a few times to in an attempt to jar/vibrate the plug out of those threads.
Old 07-24-2011, 05:39 PM   #20
Evolutionz
Evolutionz's Avatar
Ive got wetness all around my fuel rail... Ill be taking it off in the morning to investigate further. but its got spray all over the inside of my engine bay, Im just now noticing it I think
Old 07-24-2011, 05:48 PM   #21
Evolutionz
Evolutionz's Avatar
also! it runs rough, getting lower in rpms til its at retard shaky idle. likes its missing or something, someone post up a firing order please, mine is just 1,2,3,4 all the way around on the distributor cap. maybe I went retard and messed stuff up.
if I keep it at 2K with my foot it wont fluctuate, it sits pretty. but idles like shit. and there is a whining noise when my keys on but not turning from Id like to say passenger side, in the engine bay towards the bottom, weird.
Old 07-24-2011, 07:41 PM   #22
driftxninja
firing order is 1, 2 , 4, 3 bro
Old 07-24-2011, 07:41 PM   #23
driftxninja
going clockwise.
Old 07-25-2011, 09:26 AM   #24
Evolutionz
Evolutionz's Avatar
firing order is right, My car now starts up and runs fine for a few seconds. then it bogs out, its not from the start anymore. MAF? something like that? orrr what
Old 07-25-2011, 09:37 AM   #25
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
epic LAWLS
mattack69 is offline   Reply With Quote
Old 07-25-2011, 03:19 PM   #26
Evolutionz
Evolutionz's Avatar
Originally Posted by mattack69 View Post
epic LAWLS
From the last few threads youve commented on, I can tell you are helping all these help threads out.
so sincerely, go fuck yourself.
This is my daily, if you cant help, shove off.
Im getting a buddy that has literally 20 240s to come help me figure it out, he thinks its an injector or the Maf. we'll see
Old 07-25-2011, 04:34 PM   #27
!Zar!
!Zar!'s Avatar
20 240's?
Why the fuck...
Oh wait, I just noticed.
Old 07-25-2011, 05:24 PM   #28
MajorLiquidGaming
MajorLiquidGaming's Avatar
MajorLiquidGaming is an unknown quantity at this point
Send a message via AIM to MajorLiquidGaming Send a message via Yahoo to MajorLiquidGaming
check the maf....
MajorLiquidGaming is offline   Reply With Quote
Old 07-25-2011, 05:33 PM   #29
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
you said when you turn it over it makes potato gun noises which leads me to believe that your timing chain had a big jump and the valves opening at completely the wrong time.
89 2tone coupe
2jzgte swap in progress
pandaroo is offline   Reply With Quote
Old 07-25-2011, 05:37 PM   #30
Swifty
Swifty's Avatar
Swifty is an unknown quantity at this point
Fuel pump might weak had the same problem with the exhaust sound!
once i changed the pump it was all good.
Just throwing some ideas out to you.
Swifty is offline   Reply With Quote
