![]() Join Date: Jan 2010
ok whats up everyone my car sat for about 2 weeks when i left it it didnt really have any gas so i went and filled it up with a gas tank (2 gallons) tried to jump the car and nothing happened.... let it charge for alittle bit.....still nothing.... so i changed the batterie out with a different one....stilllll nothing... when i go to start the car it just makes a buzzing noise kinda but there not power to anything the radio doesnt even turn on.... my friend said to hit the start or alternator while its being jumped and turned on at the same time so i was gunna try that today once i get up but i was seeing if anyone has any other ideas on what it could be thanks
![]() Join Date: Dec 2004
Trader Rating: (58)
If you put a new battery in the car, and you have no lights/radio etc etc, then you have a loose connection, failed main battery cables (corroded or similar) or a blown fuse.
thanks |
Also when I try to start the car it won't do anything on its own but if I hook it up with jumper cables and try to start it the starter just clicks and makes a weird buzzing noise....
Trader Rating: (58)
Sounds like a faulty cable or connection on the battery (still) or on the starter, or to the main fuse panel.
You also need to make sure you have the little signal/trigger wire hooked up to the starter selenoid as well.
Yeah that ground to the starter likes to run away under the car...
Like Me on FaceBook !
ok so i checked the gounds and they seem fine i checked the fuses agian and my Alternator fuse blew agian!! i just bought a new one cause the old one was blow and now this one to...what does that mean? my alternator is bad?
Trader Rating: (58)
A faulty alternator could blow the fuse for sure.
I know this sounds funny, but the main power wire coming off the back of the alternator...it's not touching the alterantor case is it? There should be a plastic spacer behind it to prevent it from arcing out....on some cars people crank that down, crack the plastic, and it will pop fuses all day long.
