Old 01-13-2011, 12:32 AM   #1
Quiksilvia09
Quiksilvia09's Avatar
Quiksilvia09 is an unknown quantity at this point
KA s13 No start "click" noise and Buzzing sound????
Hey guy's
Kinda new to zilvia so dont kill me. :lol:
Anyway's, ever since I Swapped out my Motor to another Ka24de Ive had this problem -Well sorta, I Would click once or twice once in a blue moon-
My Car goes "click" when you try to start the car. It sound's like the Starter engages but not turn over and it has an Odd "buzzing" sound which seem's to be coming from the firewall.
also
One Headlight work but high beams are fine.
and it's the only one that will pop up
My door chime sometime's turns to a clicking sound and my
defroster button light blinks and my Dash light dont work!
Please help!
Quiksilvia09 is offline   Reply With Quote
Old 01-13-2011, 12:33 AM   #2
Quiksilvia09
Oh and it's a Bone Stock 91 Hatchback
Old 01-13-2011, 07:09 AM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
Feedback Score: 92 reviews
you got a lot going on. my car has the same problem when im trying to start, remove you steering column and find you ignition tumbler, look for the harness that comes right off it there should be. 4 wires solder on it. push that piece inward towards your key as you turn the ignition, if that fixes your problem then thats the piece at fault.
as for the other, lemme see what i can do... pm me if you still need help
S-Nation S13 is offline   Reply With Quote
Old 01-13-2011, 09:28 PM   #4
Quiksilvia09
Any Idea's anyone?!?!
Old 01-13-2011, 10:34 PM   #5
s13silvia123
s13silvia123's Avatar
bad grounds causes that
Old 01-14-2011, 12:31 AM   #6
RACEBREAD
RACEBREAD's Avatar
RACEBREAD is an unknown quantity at this point
the blue relay next to the battery goes bad make a jumper cable and see if your car starts then thats ur problem lol
look around for clutch interlock relay and thats what im talking about and there lots of threads showin similar issues
RACEBREAD is offline   Reply With Quote
Old 01-14-2011, 03:26 AM   #7
Leroy_Stickshift
Leroy_Stickshift is an unknown quantity at this point
Send a message via MSN to Leroy_Stickshift
truth be told
Leroy_Stickshift is offline   Reply With Quote
Old 01-14-2011, 03:44 AM   #8
Felipe
Felipe's Avatar
if not you need a new starter... not refurbished... not used or like new
Late Night Crew #1
Old 01-14-2011, 12:20 PM   #9
Quiksilvia09
I dont have a clutch interlock relay lol. I have a slush box
Old 01-14-2011, 12:21 PM   #10
Quiksilvia09
I have one in my room. Ive swapped it out and still the same thing
And anyone have a diagram of all the grounds?
Old 01-14-2011, 01:45 PM   #11
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
its ur EGI relay that is buzzing....bc of a lack of gounds....you can find all gounding locations in an FSM
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-14-2011, 01:49 PM   #12
murderrsirenss
murderrsirenss's Avatar
murderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enough
Send a message via AIM to murderrsirenss
maybe dead cell in your battery, borrow a finds and try to start your car.
98 s14.
murderrsirenss is offline   Reply With Quote
Old 01-14-2011, 01:58 PM   #13
Quiksilvia09
Ive tried with jumpercables and it still does it AND I used that battery to run my camry
Where can I get a FSM? They dont show the Grounding locations in my Chiltons
Old 01-14-2011, 02:14 PM   #14
HAWAII
Trader Rating: (24)
HAWAII is an unknown quantity at this point
Feedback Score: 24 reviews
Starter relay. Like what the guy said above, borrow a friend's, trace where the wire goes and see if all is plugged properly
HAWAII is offline   Reply With Quote
Old 01-14-2011, 02:35 PM   #15
japslapsilvia
fwi Auto tranny cars do NOT have a starter "relay"
#/f/tech-talk/114304...-location.html
Old 01-14-2011, 04:47 PM   #16
Quiksilvia09
someone told me to check the starter inhibitor switch. wheres that???
Old 01-14-2011, 05:13 PM   #17
Quiksilvia09
Just tried messing with it and it sounds like it's coming from the intake Mani?!?!
when I turn the key it "clicks" but the Buzzing sound stop's
Old 01-14-2011, 05:50 PM   #18
ZenKi_373
ZenKi_373's Avatar
ZenKi_373 is an unknown quantity at this point
it clicks? did you check the 100a fuse in the passenger side? mine did a similar thing with a single click...
ZenKi_373 is offline   Reply With Quote
Old 01-14-2011, 06:35 PM   #19
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Yeah this is lack of grounds. or maybe the starter wire that goes onto the little tab on the solenoid could be shot. or not on. I went to start my car after the swap and it would do the exact same thing,word for word and my starter signal wire(not positive if this is the right term) slipped off.
smoked240 is offline   Reply With Quote
Old 01-14-2011, 06:50 PM   #20
Quiksilvia09
100a? where?!
I only found a 75a
Old 01-14-2011, 06:51 PM   #21
Quiksilvia09
My wire is good Already checked
Old 01-14-2011, 07:31 PM   #22
ZenKi_373
ZenKi_373's Avatar
its the one that is literally held by bolts to the fuse box. check those 75a and 100a fuses. look very closely!
Old 01-14-2011, 08:11 PM   #23
The240Professor
Banned from the Marketplace
The240Professor is an unknown quantity at this point
Your ignition switch is wearing out and not getting a good connection when you turn the key this is a very common problem with 240's i have had 2 with the same problem i had to wiggle the key around till it started.
The240Professor is offline   Reply With Quote
Old 01-14-2011, 08:41 PM   #24
S-Nation S13
Trader Rating: (92)
lol i simply just press that connector towards the key, and i complete the connection by doing so, and wa.....la car starts heheh
Old 01-15-2011, 04:54 AM   #25
Quiksilvia09
I knoow but I already replaced the ing switch
Old 01-15-2011, 04:55 AM   #26
Quiksilvia09
Anyone have a diagram of the engine bay plugs on these car's?? and could a Dirty plug be the root of all the problems?
Old 01-15-2011, 12:50 PM   #27
japslapsilvia
OP has s13...they have 75A fuse, its NOT bolted down
here
Let me google that for you
you will be able to find what you need and throw that stupid Chiltons away.
Old 01-16-2011, 10:09 AM   #28
Quiksilvia09
here
For real it's a piece of crap. it has 3 car's in one book and it barely help's at all.
Oh and thank's for being a smart ass.
Anyway's the FSM is WAYYYYYYYYYYYYYYY better then that Chiltons Piece of crap!
Old 01-16-2011, 12:19 PM   #29
sidewayz240sxtroy
sidewayz240sxtroy is an unknown quantity at this point
My car did this and my connections wernt good enough.
sidewayz240sxtroy is offline   Reply With Quote
Old 01-19-2011, 10:45 AM   #30
Quiksilvia09
....now it start's no problem wth!
