95 DOHC swap into 93 distributor wiring
Trying to swap a 95 DOHC into 93 240. Have the 93 distributor with the external coil but the plugs on the harness I've purchased doesn't match up to the dist. One has 3 wires while the other has 4. Please help!!!!!
Is the wiring harness from a 95' or 93'?
Do need the Factory Service Manual? Click here. |
