![]() Join Date: Aug 2006
1992 coupe 4000!!!****
PRICE DROP!!!!
4000! 4000 will come with s13 seats, s14 stock wheels and open diff 4500 with s13 seats, s14 wheels, and KAAZ 2WAY LSD!! This is a 1992 coupe SE Power windows Power locks No ABS No A/C (correction) 113xxx on the car/ motor. ive owned this car for almost 2 years building it when it was basically stock. nothing done to it at all. So i have put a lot of time into this car. I am looking to move on. i own the clothing line LEAGUE (LEAGUELTD.COM) and SUPERGOOD. i want to put more money and time into it. so that is why i am selling the car 4000!!! without the Chargespeed seat (one will be provided) and without the KAAZ 2 way LSD (available for a little more) so bring your own and ill even help you install it! everything is with in 1 year old. the mods are SUSPENSION/ BRAKES -Stance GR+ coils -Megan RUCA -Megan Tension rods -Tein Inner and out tie rods -Kazama subframe bushings -Circuit sport Toe arms -Ichiba 5 lug conversion bought from Touge Factory -Z32 TT 30 MM calipers (bought 4 months ago new from Napa) -Hawk HP+ Pads -Brand new s13 Rear calipers -SS brake lines front and rear -z32 BMC -Brembo rotors all around -Clutch/Brakes all with ATE super blue MOTOR -KA24de -NGK spark plugs and wires -Oil changed with Mobil 1 every 3000 miles with OEM oil filter -All emissions removed -mild wire tuck -3in intake -Altima Fans -SS clutch line with dampner removed -Brand new Exedy clutch -Megan V2 Short shifter -Peak trans mount -Buddy Club Spec 2 exhaust -3in test pipe -Brand new Clutch Master/Slave cylinder -Walbro 255 fuel pump -Z32 Fuel filter INTERIOR -s14 passenger seat -all carpet steam cleaned -s14 seat belts -sparco harness' -still has full interior -WORKING HUD -Pioneer deck -Nismo Shift knob -Quick Release Hub -BOSS hub -Nardi steering wheel -E-brake button -Wink 5 panel -C pillar bar OTHER: -KAAZ 2 LSD -Chargespeed CF seat -Rear strut bar -Fender harness relocated into motor bay (so you dont rub at full lock) -Mild Pull and Roll on fenders -17x9 +17 MB weapons 215-45 tires bronze, (all 4) -G37 HID's -Wingless trunk -Window Tint -15mm Ichiba hub centric spacers (rear) -5mm slip on (front) -Sound deadening removed and all interior covered with POR 15 -Optima Battery relocated to trunk -Innovate Wideband 02 sensor Pros: the car runs likes new. looks good. built right. Cons- crack in the windshield, small rust around the seal, fender a little crunched, small rust on the rear right quarter ^ with my spares on ^ old tire setup SORRY FOR ALL THE PICTURES if you have any other questions call me/text at 217-637-3349 email: [email protected] Last edited by HS13KLS; 10-09-2009 at 12:57 PM.. |
Price drop !!!!
-4000!!!- stock s13 seats stock s14 wheels open diff -4500!!!- stock s13 seats stock s14 wheels kaaz 2way lsd! Last edited by HS13KLS; 10-09-2009 at 12:56 PM.. |
| chargespeed, coupe, hs13kls, kaaz |
