Hello Guys, new here. I wanted to make a post because I cannot seem to figure out what type this diff is. I've looked up on local forums or groups and I keep getting mixed answers about this. I was hoping I could have a little more insight.
My car is a 1996 240sx SE s14 - Auto (still sourcing parts for manual swap) - Open Differential -Non Abs The previous owner said it came out of a 1996 180sx Type x, and he had them pull this differential as well when they pulled the motor. It was ordered straight from japan. I am not too familiar with these cars yet so bear with me. What I see. http://imgur.com/Mwf1q6b -5 hole output shaft http://imgur.com/h0O4ze6 - I think it is an s13 back plate. http://imgur.com/rr2CcTC - Abs Sensor with 4 bolt output hole for driveshaft http://imgur.com/YwTJzWI - It is a VLSD Not sure which gear ratio it is because I cannot at the moment open it again. My question is, what would I have to do to make this fit on my car? I would think I would need an Abs driveshaft for starters. But im not exactly sure what to do about the 5 hole Diff output shaft if it would bolt up or not. Would I need new axles, and backing plate? Last edited by TheCarbon26; 04-11-2014 at 08:28 PM.. |
It looks like you have already answered your own question.
Do need the Factory Service Manual? Click here. |
