I need a definitive answer about whether or not I can keep my ecu from my automatic 1995 240sx when I swap to a manual transmission. and where is the best place to find one if needed?
![]() Join Date: Jun 2007
cable that tells it its in park is just a push pull cable just push it in. in pretty sure it just delivers continuity beetween 2 ecu pic so you could just jump the wires at the ecu. look it up in fsm theres diagrams
Will work just fine .
You will notice a couple things: You wont have a speed and rev limiter. You will have a weird initial start up idle , where it will rev then go back to normal for just a few seconds. (from experience, swap was done in my "95 s14.5") |
#7 | ||
you'll need to be patient though since they don't pop up often and when they do they tend to sell quickly be careful too, many of the ECUs I saw being advertised as manual were actually auto ones when I looked up the codes (the guide on JWTs site turned out to be usefull although not all codes for the late ECUs where on it - look it up on their site) |
I have a rev limiter still it seems like its about 100rpm higher than my friends stock 5speed though. I dont have a speed limiter and it does do that weird thing on start up and i sometimes have to give it a little gas if the weather is really cold or warm or it will stall.
but what if
my car is manual and im putting a dohc in it and i was told the only things i need to buy is headers and an ecu, so is it the same concept going into an already manual car??
your local whiteboy |
[[blast from the past!]] Just wondering - my originally-AT S13 has already been swapped to an MT, but still using the AT ECU (J5). As far as I can tell, the reverse light has been installed, and there aren't many issues I can directly associate to the MT having been swapped in. However, I have an opportunity to pick up a tuned J4 at a decent price... what might I expect if I install the J4?
Or, put another way, if the wiring has already been done for the AT ECU to accept the MT tranny, will I do any harm by now installing an MT ECU? Thanks! |
Use the MT ECU if you desire to, You might have to replace a gear sensor or two if you switch the ECU.
Mechanically speaking, swapping the ECU won't damage any of the physical transmission or engine components.
Do need the Factory Service Manual? Click here. |
