#31 |
![]() Join Date: Nov 2010
nicely done, I would have found wires that match the harness. leaving them all with is going to be a headache if there is a gremlin with in the wiring. I am liking where this is going though!
![]() No tune No life |
#32 |
Highly considering this swap. Any preferences to swapping the firewall such as cutting or drilling out the spot welds? Id perfer to drill mine out but cutting does sound easier. Just worried about warping the firewall welding it all in
#34 |
![]() Join Date: Jul 2006
yeah man, I am aware... I' had the vin welded onto this one and shaved , prepped and painted.
J-tin, doing the spot weld remover, you save more surface metal by going spot weld remover. Grind down the excess metal and you are good to go.. I just plasma cutted my daily firewall cause I got tired of those motherfucking welds on that mother fucking firewall lololol |
#35 | |
just cutting out sections, to me, is half assing it.. you gotta cut out areas for pedals, close off others, ac stuff doesnt match up so you gotta cut and cover here and there. Before you know it you got a swiss cheese slab of metal you are using for a firewall lol. If you are going to do something this extensive, do it the first time and call it a day. |
#36 |
It's been a while since I last updated.... with very limited time to work on this, this project has been taking a lot longer than expected.
Chase bays power steering line kit. I wanted a clean look for the lines that are being ran from power steering cooler to the reservoir so I went ahead and cut out 2 holes to rune the lines through. full view of the lines ran through... I placed the custom cooler right behind the latch (through 2 factory holes) using stainless steel bolts.... I just need to finish wiring the Ka f3plug from usdm to match Jdm interior harness.. I will be posting a help post shortly showing which cables I need help finding out where they go to the JDM F4 plug once this is done, refill fluids and start it up...HOPEFULLY! lol ps... anyone know of some sort of rubber lining i can use to cover the sharp edges from the holes I cut (prevent line movement to fray the lines) |
#38 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Whats the color in the engine bay? Is it a gunmetal?
My Build: The "Coupe De Ville" 1JZ Build!! |
#42 |
^ this,. they have pretty much every random size ive ever needed
cONtRol FReAkS |
#46 |
Everything is in place for this one. I ended up with a free shell to use for a "track car". So I sourced another 25 and have been playing with that one. I am only missing a few parts to get the RHD one driving. It'll be my daily.
I am needing: Driveshaft, Wiring specialties harness, custom piping for air to water intercooler, ecu, tucked rad, and a hood. I'll post more pics up on the rhd one once I get these parts in next month. |
#47 | |
![]() Join Date: Jan 2012
Otherwise looks like i could use this as a diy if i decide to go rhd! ![]() p.s. what type/awg/# of strand of wire are you using?
#48 |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
For mine I was able to move the fusebox to the trunk access hole without adding any wire, if you de loom the engine bay harness and cut the necessary wires that go to the fuse box in the drivers wheel well you can reroute all your wires back through the car and end up with the fusebox color correct wiring inside the car, just solder and heatshrink it all back up
The wires just make it back to that spot, actually works out as a nice still accessible location for the fuse box.
DLG - DIRTYLOVE |
#49 |
I ended up going a different route with the harness. Instead of tucking it back in where Nissansota has it, I sourced a S14 Jdm uncut dash and engine harness. Fuse box is in the factory position, I am going air-to-water intercooler so the battery and fuse box can stay in the factory location.
Had I stayed with the original idea, I would've definitely went back to the drawing boards and got actual colored wiring to match. |
#52 |
I daily two RHD cars. A S13 silvia and a 66 Ragtop beetle, i love driving rhd cars and want every car i own to be rhd its a blast to drive and IMO much more comfortable and gets lots of attention! looking forward to the finished product! your gonna love it!
#54 | |
![]() Join Date: Jul 2011
- License to pass on the shoulder now, because you can - Drive thru's are never conveinent because they are all window lickers anyways, I always end up having to go back in for the items they forgot to read off the list that's in front of them, now you just give retards a reason to make sure they don't fuck your order up because they think you're too awesome. - Merging on the highway, pssshshhhh, just get on doing mach Jesus, the sheep will move, they always do. Shit most of them will swerve and flip their cars off the road to avoid hitting a rabbit or squirrel, and they think they were smart in doing it too. - Making the cop walk all the way around to the other side of your car and stand in the weeds/mud/etc. to give you that ticket, fuck him anyway right? I think your rhd conversion is coming along nicely. Have fun with all the mentioned above.
#56 |
Long time since the last update.
This is where I am at now! Finally got the entire piping system done. Stainless steel everything aside of the intercooler charge pipe. From Cold side. Piping was routed inbetween the inlet and outlet of the chase bay's tucked radiator. Water barrell tucked under. From Hot side. Tail Q Bov mounted. V band elbow with o2 bung. Master power turbos are not a true 3 inch v band. Vband had to be lathe a small amount to fit the turbo v band. Stainless Steel Heat exchanger Mounting onto the back of the bash bar. Retains everything OEM. Dump tube and piping from elbow through downpipe, to my Gt spec exhaust. All stainless steel Next up... finally install all the remaining parts to get it started : Full wiring specialties wiring harness Raw pro mod fuel rail Plumb the air to water IC set up Haltech plat pro ecu Super spark series 2 coilpacks Ross tuffbond harmonic balancer HKS timing belt Tomei cam gears New timing tensioner water pump water pump Crank collar Then its dyno and tune. From there it'll be ac setup and then move towards suspension, body, and paint = FINALE! |
#57 |
![]() Join Date: Jan 2010
Trader Rating: (26)
Glad to see this thing making true progress. Glad you decided to go back to a factory colored harness because with all that white, you'd be there for DAYS trying to figure out which is which and you would have instantly regretted it.
Good shit. I like where this is headed. Can't wait to see it done! |
#58 |
Any updates on this Billy? I know it's been a long road, just curious where it was.
My SR20VET |
#60 |
He's parting the car and grabbing an R-chassis. Everything is forsale, except for a few select pieces.
My SR20VET |
