Soooo, my speedometer was not working and I swapped in a new cluster whichworks. When I start the car the speedometer immediately sits at about 13km/h so its way off of calibration, which I can deal with considering my old one didnt work at all, as long as I can figure out how much its off exactly. Anyways now the cruise control does not work which leaves me a bit confused. Before the cruise would only work if the speedo read speed, now its reading it and the cruise on button lights up on the bezel but when I push the button on the steering wheel nothing lights up in the cluster nor does it work. I switched the speedo head back into the old cluster and the cruise still does not work. If anyone has any idea of what this could be I would really appreciate it! Thanks in advance.
1990 240sx hatch Ka24e |
![]() Join Date: Mar 2011
out of curiousity does your horn still work? Just checking to see if your clock spring is still good.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
sounds like there could be a short in one of the switches . Most of the stuff in the gauge cluster area of your dash is interconnected wiring wise. I had a shorted turn signal switch that would take out the lights on the cluster. Affect brake lights and cause other anomalies. I suggest you start testing for shorts.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! #/f/sale-items/51531...ns-mounts.html #/f/tech-talk/317539...e-mouts-6.html |
Shortened wire caused alot of problems. Also happened once before when I switched to a injen gauge cluster. Also if you have tinkered w/ the ecu any there is a green rpm wire not sure of exact location but when that shorted out my speedo and a majority of gauges went nuts. |
