Installing PMAS HPX blow through maf????
i just bought a pmas hpx blow through maf..... i have the pig tail and it has 6 wires and on my s14 sr20det engine harness i only have 3 wires......
so my question is what wires do i use and witch wires go where ??? any help would be great..... i have searched high and low for any threads on this an have not found a thing..... |
![]() Join Date: Dec 2004
Trader Rating: (58)
do you have any clue if your ecu is tuned for such a thing? wires aside, you need to make sure the resolution is the same.
(you need signal/12v/ground for SR or KA ecu)
| 240sx, blow through maf, ford lightning maf, install, s14 |
