Jakes LQ9/T-56/GT-47 turbo S13.5
I bought my car back in 2006 ran a SR20 for a while then in 2010 swapped in a 6.0 LQ4 with cam and bolt-ons went 11.5 at 125mph the first time at the track. I drove it for a year or so before my most recent build up with:
LQ9/317 heads/224 cam/ ARP bolts Built T-56 Garrett GT-47 Q45 rear with 30 spline axles 6-pt cage New fuel system Tubed front end [/quote]![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() After some fiberglass and sanding ![]() ![]() ![]() ![]() ![]() ![]() [/quote]![]() ![]() ![]() ![]() ![]() ![]() ![]() Cam only Jakes Lq4 240sx dyno - YouTube Cam only with bolton results [/quote]![]() Then this ![]() After a bit of work: Welded v-bands on my flipped truck manifolds ![]() This merge pipe was fun ![]() Finally got it (Dont mind the Harbor freight flux core temporary welds) ![]() Bringing it across (ended up about 1/4" from my crank pulley) ![]() Mocking it up ![]() Time for nice welds ![]() And here she sits ![]() ![]() ![]() [/quote]Fluid was like new, with no metal on the magnetic plug ![]() Also welded in 1/2 of my roll cage. ![]() |
This is sick man a friend of mine just picked up a 6.0 to build this winter lookin forward to helping him swap it this spring.
I like your going turbo def different then your standard lsx/1 swap |
![]() Join Date: Feb 2012
YES YES YESSS!!!!
I'm a LSx man at heart and grew up on small block Chevys way before I discovered my first 240sx. I bought a sr20 and have gotten pretty deep with a large Precision turbo and big boost, but I know it's only a matter of time before I go this route. (Hopefully turbo LS2) I'm looking forward to some updates. This is common in other chassis, but just not so common with the 240sx crowd. I take it your a weekend warrior at the drag strip? |
Love it!! I have been tossing around the idea of a 5.3L Turbo setup. But I am not a quarter mile guy (once in a while). Sounds like an NA setup would work for me (like your LQ4 setup). There is nothing like the sound of a V8
Great job man! I am looking forward to more updates on this build as she goes for sure!
1998 240SX SE- Low, slow and ready to roll
Thanks guys,
Im definately not a drag only guy, ive done my fair share of sliding and still do. On the Turbo LSx s13 I have recently put in a Walbro 400lph pump, Q45 solid mounted diff with 30 spline axles and hubs, 1/2' feed and return fuel lines, modified the front "Power brace area" setup with box tubing. Yesterday I was building up the new motor with ARP bolts, cam, melling oil pump, heads, and valvetrain. Got a built tranny also ![]() This is my Daily Driver S14 with LS1/t56 ![]() ![]() ![]() |
ill tongue punch her fart box
![]() Join Date: Sep 2009
this is cool shit. im not a huge fan of throwing a turbo to it, but still cool none the less.
i used to have an ls1 s13 and now rb s13 with eventually make it back to LM4 with a modest goal of 300 to the wheels. |
I havent take my S14 to the track yet but, a guy I know has a s14 ls1 that's bone stock even with stock manifolds, and he broke into the 11's. But he has a ton of passes on it, I would say low 12's consistently.
I am looking forward to getting out there and getting to the fab stuff. I run a welding shop in the military, so I have access to some cool tools and a damn good welding specialist as well
Thanks for the inspiration!
#19 |
ill have to ask jake. he lives in the sticks with no internet and has forgot all about the internet. this car is also sitting in the deep dark shadows of his massive shop. thanks for bumping a old ass build tho
#22 |
![]() Join Date: Apr 2003
Trader Rating: (33)
You can use a DBC setup....I have my LS6 intake using an eBay bracket and 00 LS1 throttle. I'm using a 411 PCM which is DBC and Wiring Soecialities Harness which are both setup for DBC.
