Hey everyone, I'm getting in my CODY ACE bracket to use my KA (95-98) in my redtop SR20 engine. I have all my old stuff (compressor, lines, etc.) Is this going to be a hard process in getting this too work? All help is accepted, I'm planning on doing it this weekend. If anyone has done it please give me some tips/advise.
![]() Join Date: Dec 2004
Trader Rating: (58)
Hey brother!
It's a bolt on and go kit! Check out: Gallery :: AC Conversion Brackets for install pictures for your kit (s14 to redtop) ![]() Just remember to grind off the two lower nubs on the factory bracket and yo'll be good to go! Once you et the brackets on the SR bracket, keep them a bit loose...mock up the compressor, and then tighten them all down for a perfect fit PM me if you need any other help!Thanks again for the wait...trust me, I didn't like holding onto so many pre pays (I had 15 kits total) but I got them all out today, after getting all of the belts in You should easily have it by the weekend ![]()
