hey guys i have a redtop s13 just tried to turn her over for the first time today butttt...my new walbro isnt kickin on at all i really have never had this issue with the sr swap guy have any ideas/suggestions thanks a ton
If the pump isn't priming the first thing I would be doing is checking for correct powers and grounds at the pump connector. Also make sure there is good pin contact in the connector.
If you've got no power there then you have a wiring issue, as you've just completed your swap by the sounds of it there is a good chance you simply missed something, wired something in the wrong way or something got pinched upon install. |
Its s13 chassis and i know its a wiring problem i guess i just dont know where to start looking not sure what part of the harness goes or sends power to the fuel pump ive checked all relays and fuses and the wiring by the battery box
Black with yellow stripe supplies fuel pump with power. Check if it had 12v with the key 'on'
If not, start with fuse. And work towards relay/pump with multi meter
@UpshiftEngineering |
If the fuse is good and the wiring is good then I would check the actual pump. I have had walbros lose the filter right after putting it in and fail right away.
Like Me on FaceBook !
| fuel pump, help 240sx, problem, s13, sr20det |
