![]() Join Date: Feb 2011
is there tips on cleaning head studs thread in block
is there a tips where i could clean the head studs out because when i reinstall arp head studs none of them lines up
Take an old stud/bolt and cut a decent size groove on one side. Clean it up so there are no burrs and run it down the threads. You can also use the correct tap to clean the threads up as well.
My SR20VET |
![]() Join Date: Sep 2006
go to a parts store and borrow a "thread repair set,"
itll have the tap you need. (m10x1.5 i think?) i borrowed mine from oreilly. there is a deposit but once you return it you get your money back. that or make your own tap like previously mentioned. after that, if you have a pressure washer you can hit the hole with that and after that if you have pressurized air you can use that to get all the water out of there.
formerly known as "hotboiblaze" ![]() ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
I sprayed my holes out with brake clean to remove any oily deposits. Then I used compressed air and hit each one with that as well. All that was in preperation for a fresh/clean slate for my ARP lube...
My SR20VET |
The ARPs do not bottom out in the hole. They are not long enough for that unless you've bought the ARP/Mazworx spec items. Hand tighten them into the block you can use the Allen key to help, but do not put any torque on them.
My SR20VET |
Two of them are taller if I can remember correctly. I would try to get them even, but I'm OCD like that
My SR20VET |
![]() Join Date: Sep 2005
With the head off and studs in, it looked like the front six where higher than the rear four, or vice versa.
When the head gasket, and head was fitted, and studs reinstalled, they all appeared to protrude the same amount. Even after final torquing they all are identical in remaining thread height. 20, 40, 60, 80, 80 ARP lube
#17 |
![]() Join Date: Sep 2012
Cut a slit in old bolt:
Spray carb cleaner down the holes in the block. Thread the slotted bolt in each hole. Repeat process 3 times, then spray with compressed air to dry it all out. That's what I did.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane |
#19 |
That's normal... I just couldn't remember what two sat taller in the block.
My SR20VET |
#21 |
Yeah, check the one sitting higher than the rest that aren't in the middle. The middle ones will be higher.
My SR20VET |
#22 |
I think it should be fine, i put the head on just to measure the threads they all seems to be fine and should be torque down the same way. I'll see wsp after i assemble everything together
